Re: AL wedge Indy Maxx or Keith Black
[Re: tntmachine]
#836349
10/23/10 02:30 AM
10/23/10 02:30 AM
Posts: 1,624 Orange County, Ca.
B1CUDA
Orange County, Ca.
I have a 588 rotating assembly and B1MC top end. Should make 1000+ HP, but I'm needing a block. I would like aluminum, but may settle for iron. Which direction should I go.
Back to topic....... If your motor is going to be a 588, I would think that, if your heads, intake, and cam profile are in unison, you should be able to make, at least 1150HP.
[Re: tntmachine]
#836350
10/23/10 02:39 AM
10/23/10 02:39 AM
Posts: 19,379 Las Vegas
Al_Alguire
Las Vegas
To the OP, in all honesty if max HP is what you are after then cast is gonna be the best bet. While it is debateble how much power is lost with aluminum I think we can all agree it will be some. I also agree based on what my deal makes that with a 588 I would think 1100+ is more than doable. Someday I will grow up and build a big motor, but is 588 even big these days Either way get after it, Going to be nice to see that old Cuda running real fast again. That is a good working car you got for sure. BTW Chris, next time you talk to Jason ask him what his opinion of that cam is now. He is even less impressed now after the failure.....
[Re: Al_Alguire]
#836353
10/23/10 03:29 AM
10/23/10 03:29 AM
Posts: 2,401 Tucson, Arizona
MRMOPAR
Tucson, Arizona
Indy low deck with 440 mains. Got it direct from Indy, no complaints at that time.
68 RR 528" INDY MAXX
07 2500 CTD
Southwest International Raceway - IHRA - Tucson, AZ
[Re: tntmachine]
#836356
10/24/10 04:47 PM
10/24/10 04:47 PM
Posts: 627 IN
BIG BEAR
IN
It is Ticer's old Cuda. I bought it roller so I was running a 496 -1 in it. I'm going to step it up to 588 cid B1MC. I have everything I need except the block and oiling system. I started this thread because I was curious if an Indy aluminum block would hold up for me. I know that KB is the top of the line but I never see any of them, in a wedge version, for sale; once in a while you'll see an Indy for sale. If I don't go aluminum the Koleno is what I'll be looking for.
Good luck with whatever you decide to go with
[Re: tntmachine]
#836361
10/25/10 09:08 AM
10/25/10 09:08 AM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
KB block here.
[Re: B G Racing]
#836363
10/25/10 02:07 PM
10/25/10 02:07 PM
Posts: 4,866 North of Detroit
HemiDart68
North of Detroit
The first time I looked at KB block up close was last winter. I bought it and a set of heads, new but unused. After looking at the quality of the block, I will never use anything but a KB block again. Not saying there isn't other quality stuff out there, but they are in my opinion the best.
In God we trust, all others pay cash.
www.lightnens.com (Home of the world's fastest Paint Job)
[Re: B G Racing]
#836364
10/25/10 02:25 PM
10/25/10 02:25 PM
Posts: 341 Highland beach Fl
poisondart2
Highland beach Fl
We suggest that you chose what block works for your intended build.Consider the power level,combo parts,time constraints,availability as well as a realistic budget.Research reliable sources of experiences and results from respected builder and ask questions as to why the preferr a specific block and the advantages as well as the disavantages.If your building under a 1200 HP engine most after market blocks would work fine,If your got for higher HP,goe for the best block your budget can afford.
Would not the BEST block be the one that doesnt break or if it did can be fixed? I thought i saw the KB block advertised for $5,100.00 which aluminum block is cheaper? My
[Re: poisondart2]
#836365
10/25/10 02:40 PM
10/25/10 02:40 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
Tell me which one won't break and it's worth it no matter what the cost.I would never tell anyone who's block to use.It's up to each person to decide,I only provided a opinion of a criteria to use to make a qualified decision on which to choose a block.If I were building engines over 2000 HP then I would rely on the experts opinion whom I have respect for to steer me in the right direction.As said many times here at BGR we build reliable bracket engines not exotic ticking time bombs.I'am not here to debate who's block one should choose.
[Re: B G Racing]
#836367
10/25/10 03:02 PM
10/25/10 03:02 PM
poisondart2
Highland beach Fl
I didnt mean to offend just saying that for the money what block is better or equal to the KB ? The fact that one is not making 2000HP but making 700 Why wouldnt you want the best block you can find with-in the same cost factor? I would guess that in reading these threads for years that KB blocks are the best Aluminum blocks as I have never read anything bad about them.I would want to know if (I) asked what was the best block for the money from a expert with hundreds of builds.I would also think that most people on here use the info here to make decisions as what to buy and who to use for services.I do and this is why i posted this.Sorry
[Re: poisondart2]
#836368
10/25/10 05:24 PM
10/25/10 05:24 PM
Posts: 61 N. IL
tntmachine
N. IL
No offence was taken. Just trying to collect as much info as I can before I decide. I agree that the KB is the best bang for the buck, new. I've got an order form for one setting on my desk right now. If I don't find a used KB or Maxx by December I'll be sending in the order.
