360 heads on a 273? #836048
10/22/10 10:47 AM
10/22/10 10:47 AM
N.E.Ohio
P
Polarabill Offline OP
P
N.E.Ohio
Just checking to make sure 360 heads from a 73 will bolt on a 67 273 with out problem.Thanks.
This would be so much easier if I knew what I was doing...
Re: 360 heads on a 273? [Re: Polarabill] #836049
10/22/10 10:51 AM
10/22/10 10:51 AM
NY usa
540challenger Offline
NY usa
They will bolt on no problem. However i don't know if the 1.88 valve will clear the bore without notching. Also use a 360/340 intake so the ports match. THen the last thing to check is if you have dome piston in the 273 i know they clear the 273/318 heads opne or closed but just double check to make sure the Dome clears the head I would assume it woun't be a problem b/c the 360 head has a huge chamner compare to the stock 273/318 stuff
Re: 360 heads on a 273? [Re: 540challenger] #836050
10/22/10 11:02 AM
10/22/10 11:02 AM
N.E.Ohio
P
P
N.E.Ohio
Thanks for the info.
Re: 360 heads on a 273? [Re: Polarabill] #836051
10/22/10 11:27 AM
10/22/10 11:27 AM
scratchnfotraction Offline
notch the block for sure
best to mock it up with crank/rods/pistons out and look up from the bottom to see/measure clearance of the valve to cyl wall
have to do a bunch of grinding/porting to get the flow straighten out for max HP as the valve is really shrouded at the cyl wall even with notches
IMHO a set of the 318 closed chamberd #302 head would be better when opend up for the 188/160 valves
Re: 360 heads on a 273? [Re: scratchnfotraction] #836052
10/22/10 11:32 AM
10/22/10 11:32 AM
N.J. north west
1972challenger Offline
N.J. north west
You will need to clearance the block. The late model 318 heads are the way to go. The 360 head will drop the compression ratio way down.
Re: 360 heads on a 273? [Re: Polarabill] #836053
10/22/10 12:10 PM
10/22/10 12:10 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
It will work, may require notching the block for valve clearance or if you valve job on the 360 head is as bad as most you can have the valve diameter turned down slightly to get the clearance. It was mentioned already but the comppression will be TERRIBLE!!!! It will be about 7.2 with the .039 felpro head gasket! And in order to take advantage of the extra airflow you will need to rev it VERY high
Re: 360 heads on a 273? [Re: HotRodDave] #836054
10/22/10 12:13 PM
10/22/10 12:13 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
The 67 and older 273-318 heads have the smallest chambers and most flow of the small valve heads. I have heard of a couple SS racers now who can not run as fast with the 302 head as the 315 and 920.
Re: 360 heads on a 273? [Re: HotRodDave] #836055
10/22/10 12:36 PM
10/22/10 12:36 PM
ddartdude Offline
ddartdude  Offline
I'd use the 920 heads. That's what came on the D/Darts and they ran in the high 12's back then.
Re: 360 heads on a 273? [Re: ddartdude] #836056
10/23/10 12:26 PM
10/23/10 12:26 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Are you sure the D-dart had the 920? I beleive they only came on 67s and were on both the 273 and 318. The 66 should have had a 315 casting, the only differance however was the bolt angle on the intake flange, it was changed to get the intake bolts in easier on the 318 dual plane intake that came on some 318s.
