Re: 727 tranny not pulling in kickdown mode
[Re: 1_WILD_RT]
#835959
10/21/10 11:16 PM
10/21/10 11:16 PM
Posts: 2,640 Port Reading, NJ
roadrunner7070
Port Reading, NJ
Yes the tranny has all 3 gears. When you floor it the engine revs and it kicks down to second gear but the car doesn't seem to go faster than 60 mph. It just hits a point and will not go faster unless I let off the pedal and get back to 3rd gear. It doesn't take off like it should. The guy that did the tranny also replaced the torgue converter with a stock one.
[Re: roadrunner7070]
#835960
10/22/10 12:12 AM
10/22/10 12:12 AM
Posts: 2,008 s. e. pa.
calrobb2000
s. e. pa.
hi check your fuel psi at speed ! not at idle ! week fuel supply , cloged filter ,points shot ,timing incorrect ,dirty air filter ,dist not advancing , cam timing off ! ![](/ubbthreads/images/graemlins/hammer.gif)
[Re: calrobb2000]
#835961
10/22/10 10:41 AM
10/22/10 10:41 AM
roadrunner7070
Port Reading, NJ
not at idle !
I will check. I do have new fuel tank,fuel lines. No points. Have Mopar Electronic Ignition. New air filter. Taking it back to my guy next week to check timing.
#835962
10/22/10 04:09 PM
10/22/10 04:09 PM
Posts: 26,051 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Do you have a tachometer?
