69 Road Runner 70 A833 which crossmember? #835928
10/21/10 10:28 PM
10/21/10 10:28 PM
Virginia, USA
rocket34 Offline OP
rocket34  Offline OP
Virginia, USA
I have a 1969 Road Runner and a 1970 A833 which cross member? I think the mount on the 70 is further back (it has both the B and E shift mounts)so I think the 70 would work. What do you guys think?
69 Road Runner work in progress
Re: 69 Road Runner 70 A833 which crossmember? [Re: rocket34] #835929
10/21/10 10:45 PM
10/21/10 10:45 PM
Western Pa
joewhite440 Offline
joewhite440  Offline
Western Pa
I think A 68/69 Automatic or any 70 b-body will work. You may have to drill the holes out in the 70 brace to use your 69 Bolts.
I think the 70 only used 3/8 bolts through the frame.
Re: 69 Road Runner 70 A833 which crossmember? [Re: joewhite440] #835930
10/21/10 10:53 PM
10/21/10 10:53 PM
Virginia, USA
rocket34 Offline OP
rocket34  Offline OP
Virginia, USA
Thanks!
