Magnum eletric water pump #835923
10/21/10 10:23 PM
10/21/10 10:23 PM
Chicago
Lee Offline OP
Lee  Offline OP
Chicago
What are you using for a eletric water pump on a small block magnum?
Lee
Re: Magnum eletric water pump [Re: Lee] #835924
10/21/10 10:48 PM
10/21/10 10:48 PM
Western,Pa.
MagnumDartSport Offline
Western,Pa.
I hae a CSR on mine.It works,BUT,if it evers goes out I'm going back to the factory water pump and viscous fan with a shroud.
With the factory pump and fan I could rarely get the motor above 180 degrees.
The CSR doesn't seem to cool the car quick enough.
Re: Magnum eletric water pump [Re: Lee] #835925
10/21/10 10:57 PM
10/21/10 10:57 PM
lino lakes,MN
onebaddakota Offline
lino lakes,MN
I run the CSR. It cools the truck fine. I put mostly street miles on it.
10.56 at 125.6, with a 1.43 60 ft. E85, Hyd. Roller 410 magnum,full exhaust, 3500 race weight.
Re: Magnum eletric water pump [Re: onebaddakota] #835926
10/21/10 11:08 PM
10/21/10 11:08 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
How are you guys running your belt to bypass the water pump but still retain AC and PS? Pics would be great!
Re: Magnum eletric water pump [Re: TheOtherDodge] #835927
10/22/10 12:02 AM
10/22/10 12:02 AM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
No a/c...
