Help on my sb magnum build, solid roller?
#835331
10/21/10 12:56 PM
10/21/10 12:56 PM
Posts: 32 Zanesville, Ohio
Last_in
Zanesville, Ohio
Who is running a solid roller in a factory Magnum block?
Currently, the truck(98 club cab Dakota) ran a 12.4 @ 111 with a 1.85 60' n/a. Now I want to turn it up and hit 10's.
So now that my goal is 10's I come to you guys for suggestions. I still want it to be streetable. But what I'm looking at doing is changing my current setup. I was thinking a solid roller, get the heads ported, be able to spin it past 7,000 rpm and re-ring it for nitrous plus some head gaskets that will hold up to a decent shot.
Current combo: 408 ci magnum Internally balanced comp .585in/.580ex 242/248 112 lsa 4" Forged Eagle 6.123" Eagle H-Beam forged SRP forged pistons .030 over, -16.9cc ARP head/main studs Edelbrock magnum aluminum heads 6.936 in. push rods, 1.6 rr M-1 4 bbl with 2 bbl adapter F&B 58mm tb, flows 1200 CFM 3800 pi viper stall
Race weight of a little over 4,000 pounds, 46RE with 3,800 stall, and 3.91 gears.
I can easily send my converter back to PI to get it restalled if needed.
What do you guys suggest for 11's n/a and 10's on the spray? Don't want to change transmissions or gearing, and no weight reduction.
Thanks!
Re: Help on my sb magnum build, solid roller?
[Re: Last_in]
#835332
10/21/10 03:13 PM
10/21/10 03:13 PM
Posts: 4,953 Houston, Texas
TheOtherDodge
Houston, Texas
First, and the toughest question is for you to define "streetable". We all have different ideas on that. Im my mind, I can tell you that a solid roller will take away from some of the "streetable" in your truck. A solid roller is tough on all the valve train, especially at low rpms such as in stop and go traffic, etc. There will be those that say they run a .800 lift solid roller on the street for years, etc... My advice? To run 10's and keep it very streetable???? Turbo or SC. At least Im following my own advice! ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: Last_in]
#835335
10/21/10 04:25 PM
10/21/10 04:25 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
Thanks!
Port the heads and change the cam to a custom hyd roller with about .600 lift. Beehive springs and you'll pick up a bunch and stil be streetable. Brian
Brian Hafliger
[Re: Brian Hafliger]
#835336
10/21/10 04:31 PM
10/21/10 04:31 PM
Posts: 142 Maryland
Sick 660r
Maryland
Its the 59* valve train that limits you rpm wise. Step up to a 48* R3 if you really want to turn some rpms.
2000 dakota
418 magnum
paxton novi 2k
T56
#835340
10/22/10 12:48 AM
10/22/10 12:48 AM
Last_in
Zanesville, Ohio
That's what it looks like I'll have to do.
So I wouldn't be able to turn over 7,000 with a 59* magnum block even if I had a solid?
[Re: 70Cuda383]
#835343
10/22/10 11:06 AM
10/22/10 11:06 AM
Last_in
Zanesville, Ohio
Maybe I was wrong, I thought there were some guys running over 7K in a factory magnum block. maybe not?
I'm down to try it with a solid roller. It's just an engine, if it breaks it breaks. No ones losing a life here.
[Re: emarine01]
#835347
10/22/10 11:40 AM
10/22/10 11:40 AM
Posts: 20,679 in a cattle trailer down by th...
Guitar Jones
I think if the head flow, cam and springs will support over 7k the 59* lifter angle wont be an issue, just look @ the w2 & w5 series offset intake angle and they buzz way over 7k
I was twisting my W5 340 to 8K, 8500 in the water. I'm currently buzzing my 360 to 7200 and it's still a stock crank and rods. Been together for 10 years now.
[Re: ademon]
#835348
10/22/10 11:51 AM
10/22/10 11:51 AM
Last_in
Zanesville, Ohio
Am i the only one that thinks his current 408 combo should be much faster than 12.40's? Maybe ditch the 2bbl tbi?
What DVJcuda said. I probably weigh right around there.
So spinning past 7k isn't out of the question, this is what I like to hear!
[Re: mphsmitch]
#835349
10/22/10 12:15 PM
10/22/10 12:15 PM
Posts: 41 Ontario, Canada
rtspeeddemon
Ontario, Canada
I am hitting my stock 360mag with a 175 shot and it picked it up from 12.55 @ 107 mph to 10.92 @ 122 mph. Works for me
Your also running a far lighter truck. Gen 3's are way heavier then your Gen 2.
[Re: DJVCuda]
#835350
10/22/10 12:41 PM
10/22/10 12:41 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
remember that truck is 4400 lbs
I think 4400 is a stretch, maybe 4200...
my 98 club cab with a big block, TKO-600 trans is tipping in at 4200 with me in the seat. his 360 with iron heads won't be that much lighter than my big block, but I think whatever weight he saved on the small block, he loses with the heavy auto/OD unit, so they're probably a wash.
Also, his truck is in full street trim. no weight reduction, full factory interior, full factory sheet metal, plus he's got AC, Power steering, a decent stereo system...
Dakota's have great styling, but they're heavy pigs!
![](/ubbthreads/images/graemlins/hammer.gif)
**Photobucket sucks**
