I know that slant six "A" body steering boxes ususlly had a bushing rather than a roller bearing setup on the sector shaft. Obviously the weight of the B over the A is the reason. Is there a major disadvantage to using a decent A body box in a big block B body car? Is there a way to convert the bushed box to use a bearing?
This is the land of the free because of the brave
