PILOT BUSHING #835143
10/21/10 01:04 AM
10/21/10 01:04 AM
Richmond , Virginia
chagjr Offline OP
chagjr  Offline OP
Richmond , Virginia
Where can I purchase the .914 OD pilot bushing for the automatic cranks. My Napa store said the 615-1033 is discontinued.
F.A.S.T/1969 SUPER BEE/383/AUTO/AVS 11.58 @ 117.98 1.71 60ft mph F.A.S.T Legal
1969 DART SWINGER/340(420CI)/6.52 @ 105.39 1.45 60ft (1/8 mile)10.22 @130.5 (1/4 mile)
Harry
Re: PILOT BUSHING [Re: chagjr] #835144
10/21/10 01:13 AM
10/21/10 01:13 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
You can always get a pilot bearing from a 90's dodge ram gas powered manual trans truck instead of the bushing. They should be able to get it for you no problem.
Re: PILOT BUSHING [Re: chagjr] #835145
10/21/10 01:18 AM
10/21/10 01:18 AM
DE
Ply72rr Offline
Ply72rr  Offline
DE
I do not know if those bushings were available when I swapped motors back in 1983,if they were I didn't know about them. I used a standard bushing and turned down the outer circumfrence on a brake lathe.
Re: PILOT BUSHING [Re: DaytonaTurbo] #835146
10/21/10 01:22 AM
10/21/10 01:22 AM
Richmond , Virginia
chagjr Offline OP
chagjr  Offline OP
Richmond , Virginia
No modifications needed to shaft or splines? A 1970 833/1967 383 Auto motor.
Harry
Re: PILOT BUSHING [Re: chagjr] #835147
10/21/10 01:28 AM
10/21/10 01:28 AM
Manitoba, Canada
Manitoba, Canada
No modifications, drops right in and will fit your crank and trans perfect. For the mid 70's 440 I have, it's the only option because the crank is not drilled at all.
Re: PILOT BUSHING [Re: DaytonaTurbo] #835148
10/21/10 01:33 AM
10/21/10 01:33 AM
Richmond , Virginia
chagjr Offline OP
chagjr  Offline OP
Richmond , Virginia
I just looked on ebay to get an idea of what it looks like...Is there any specific years in the 90s or maybe a part#
Harry
Re: PILOT BUSHING [Re: chagjr] #835149
10/21/10 02:42 AM
10/21/10 02:42 AM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Re: PILOT BUSHING [Re: chagjr] #835150
10/21/10 11:26 AM
10/21/10 11:26 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Try bearing supply shops.
