Re: 65 Coronet wheel offset
[Re: Captain Flapjack]
#835063
10/20/10 11:38 PM
10/20/10 11:38 PM
Posts: 417 reynoldsburg,ohio
poppaj
reynoldsburg,ohio
I have stock well wells on mine with a stock length Dana 60. I use a 12" wheel with a 7" backspace. Slicks are 10.5w x 29.5
AA/NSS 65'Coronet "Whompin Wedge" Pop & Son Performance 557" B-1 power John Holt Chassis
[Re: Tech Instructor]
#835064
10/20/10 11:41 PM
10/20/10 11:41 PM
Posts: 43,157 Bend,OR USA
Cab_Burge
What width rear end and axles are you using or are you using the stock 1965 8 3/4 width rear end? It does make a difference If your using a stock width 1965 rear end and the leaf springs are move into the sub frame 5 or 5.5 inch on the back side on a ten inch rim or a 6 or 6.5 inch on a twelve inch rim works well If not a stock rear end
