Page 2 of 15 1 2 3 4 14 15
Re: "Don't ask me how I know..." [Re: Just Cameron] #633
07/11/03 02:40 PM
07/11/03 02:40 PM
Santa Rosa, NOR*CAL.
Just Cameron Offline
"It seemed like a good idea at the time"
Re: "Don't ask me how I know..." [Re: Just Cameron] #634
07/11/03 02:45 PM
07/11/03 02:45 PM
Re: "Don't ask me how I know..." [Re: Just Cameron] #635
07/11/03 02:49 PM
07/11/03 02:49 PM
If you don't put the stainless trim tabs in before putting the windshield in, you have to pull the windshield back out, then put the clips in and put the windshield back. You will probably ruen the gasket and need to buy another.
Re: "Don't ask me how I know..." #636
07/11/03 02:50 PM
07/11/03 02:50 PM
Petite women won't bend Daytona and Superbird wings.
Re: "Don't ask me how I know..." [Re: BSharp] #637
07/11/03 02:53 PM
07/11/03 02:53 PM
Kissimmee, Florida
aarlucas Offline
aarlucas  Offline
Kissimmee, Florida
A diesel fuel fill nossle will fit into to a car that uses regular gasoline. Then they don't run to well!! "Don't ask me how I know!
Re: "Don't ask me how I know..." [Re: Just Cameron] #638
07/11/03 02:55 PM
07/11/03 02:55 PM
Dumping antifreeze on a fire doesn't put it out but actually turns it into a raging inferno!
Re: "Don't ask me how I know..." [Re: aarlucas] #639
07/11/03 02:56 PM
07/11/03 02:56 PM
Inner fenders are not a secure place to leave a "710" cap.
Using duct tape to replace the one that your fan kicked onto the freeway ramp works pretty well, until your engine heats up.
Don't ask me how I know this.
Re: "Don't ask me how I know..." [Re: Just Cameron] #640
07/11/03 02:59 PM
07/11/03 02:59 PM
The wires to ypur ammeter can fuse themselves together, creating years of electrical gremlins.
A small piece of metal and a gob of poster tack stuffed into the steering column harness connector will return your brake lights to operational, but don't try using your hazzard lights afterwards.
Re: "Don't ask me how I know..." [Re: Just Cameron] #641
07/11/03 03:01 PM
07/11/03 03:01 PM
Trying to jump a General Lee pedal car is a good way to maim yourself.
Re: "Don't ask me how I know..." [Re: Just Cameron] #642
07/11/03 03:04 PM
07/11/03 03:04 PM
Candler, NC
Roughrdr Offline
Roughrdr  Offline
Candler, NC
A burping carb can give you a nice clean, but tender and smelly, shave and a haircut
Chains of habit - too light to be felt until they are too heavy to be broken
Re: "Don't ask me how I know..." [Re: Roughrdr] #643
07/11/03 03:05 PM
07/11/03 03:05 PM
Candler, NC
Roughrdr Offline
Roughrdr  Offline
Candler, NC
LOng hair and carbs don't play well with each other
Re: "Don't ask me how I know..." [Re: Just Cameron] #644
07/11/03 03:06 PM
07/11/03 03:06 PM
El Cerrito, by San Francisco
last426 Offline
last426  Offline
If you don't put a bowling ball into a bowling ball bag before you put it in the trunk it will roll from side to side with every turn and dent you trunk from the inside out (at least that's what I heard).
Re: "Don't ask me how I know..." [Re: last426] #645
07/11/03 03:07 PM
07/11/03 03:07 PM
Kingsburg Calif.
Quikshft Offline
Quikshft  Offline
Kingsburg Calif.
Don't sandblast sheet metal!
Re: "Don't ask me how I know..." [Re: Roughrdr] #646
07/11/03 03:08 PM
07/11/03 03:08 PM
Candler, NC
Roughrdr Offline
Roughrdr  Offline
Candler, NC
When locking keys in trunk, It would be easy to go in thru the back seat if it wasn't for the metal plate mandated by NHRA to seperate fuel cell from passenger compartment
Re: "Don't ask me how I know..." [Re: last426] #647
07/11/03 03:09 PM
07/11/03 03:09 PM
Taking your grilfriend to the local Pick-N-Pull on her birthday will lead to problems in the relationship. Even if it is "Half-Price Weekend and maybe you'll find something for her car, too."
Re: "Don't ask me how I know..." [Re: Just Cameron] #648
07/11/03 03:09 PM
07/11/03 03:09 PM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
allways replace a single line master cylinder with a dual line!
Re: "Don't ask me how I know..." [Re: BSharp] #649
07/11/03 03:56 PM
07/11/03 03:56 PM
Amarillo, Texas
65Dart270 Offline
65Dart270  Offline
Amarillo, Texas
Becoming the shortest path of resistance on your coil wire will make your girlfriend happy, but it will not make you feel so good. Don't ask me how I know.
"Although prepared for martyrdom, I preferred that it be postponed."
Sir Winston Churchill
Re: "Don't ask me how I know..." [Re: 65Dart270] #650
07/11/03 04:14 PM
07/11/03 04:14 PM
A well placed backfire upon startup is a great way to test the restrictiveness of your exhaust system.
If your muffler blows open at the seams, it was way too restrictive, and you have just modified it for WAY less backpressure.
Re: "Don't ask me how I know..." [Re: BSharp] #651
07/11/03 05:01 PM
07/11/03 05:01 PM
Yorktown VA
motorheadjohn Offline
Ridin' Shotgun
Ridin' Shotgun
Yorktown VA
(1) If you're changing oil on your motorcycle and fail to replace the drain plug, the new synthetic oil is guaranteed to run out on your boot and make a hard-to-clean-up mess.
(2) Always check the operation of your automatic trans kickdown linkage, and verify there is no binding, with the engine off, before taking it on a test drive.
(3) If your gas pedal sticks on the floor due to a bound kickdown linkage, and you're going down a 2-lane road quickly approaching slower traffic, turn the key off. Do not turn it back to where it locks the steering wheel. Also, failure to immediately bump transmission into neutral may result in blown-out mufflers.
Don't ask me how I know.....
Chicks in the mirror
are fatter than they appear
Re: "Don't ask me how I know..." [Re: BSharp] #652
07/11/03 05:08 PM
07/11/03 05:08 PM
Sun City, AZ
MTTwister Offline
super gas
MTTwister  Offline
super gas
Sun City, AZ
Brake Fluid makes a great anti-coagulant. External use only recommended.
Sold the Duster a few years ago...
