Re: slicks
[Re: Kudakidd]
#834428
10/20/10 09:32 AM
10/20/10 09:32 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Up the tire pressure so it just spins some... what is the cam and where is it installed at
Mopar's .509" straight up( I know, old school)
Did you degree it
Re: Slicks Bite, Car Bogs - What to do?
[Re: Cudajon]
#834432
10/20/10 10:42 AM
10/20/10 10:42 AM
MR_P_BODY
What flywheel are you using and what is the rear gear?
I'm thinking he has the light weight fly wheel in it and could use the heavier one to carry it through
[Re: DodgeCharger]
#834436
10/20/10 12:49 PM
10/20/10 12:49 PM
Posts: 1,491 Oologah, Oklahoma
Big Squeeze
Oologah, Oklahoma
If it bogs, and the timing is right, it needs more fuel.......Carb is too big or it needs more pump shot........I can leave anywhere from 1,500 to 4,500 with my stick car and slicks and it NEVER bogs even when it had 3.54 gears............ BTW, there's a HUGE difference between yanking a motor down because the flywheel is too light or the gear is too high and a bog.......
If you can't handle the truth, you're living a lie.......
[Re: Big Squeeze]
#834441
10/20/10 02:02 PM
10/20/10 02:02 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
