Page 1 of 3 1 2 3
Slicks Bite, Car Bogs - What to do? #834425
10/20/10 09:02 AM
10/20/10 09:02 AM
Witness Protection Program
Kudakidd Offline OP
Kudakidd  Offline OP
440 in a Duster, and yes it's a 4 speed. Even popping the clutch at 4 grand, the car will still lay down and hesitate giving me 2.10 60 footers! I'm using M/T drag Radials set at 18psi. I tries moving the card accelerator pump cam to the #2 position and it didn't help at all. Best time on a 60 degree nite was 13.16 at 106 mph. Any help?
Re: Slicks Bite, Car Bogs - What to do? [Re: Kudakidd] #834426
10/20/10 09:08 AM
10/20/10 09:08 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Up the tire pressure so it just spins some... what
is the cam and where is it installed at
slicks [Re: MR_P_BODY] #834427
10/20/10 09:25 AM
10/20/10 09:25 AM
Kudakidd Offline OP
Kudakidd  Offline OP
Mopar's .509" straight up( I know, old school)
Re: slicks [Re: Kudakidd] #834428
10/20/10 09:32 AM
10/20/10 09:32 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Did you degree it
Re: Slicks Bite, Car Bogs - What to do? [Re: Kudakidd] #834429
10/20/10 09:37 AM
10/20/10 09:37 AM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
Add some juice (N20).
8.30's @3400 lbs
Re: Slicks Bite, Car Bogs - What to do? [Re: Kudakidd] #834430
10/20/10 09:42 AM
10/20/10 09:42 AM
Roanoke Va
gearjammerdart Offline
Roanoke Va
What rear gear are you running? Tire size? What do you turn the motor to?(rpm)
Donald
69 Dart swinger 417 W8 Liberty 5 speed
6.03 @114/9.49 @141 on motor 5.30 @131 on juice 1/8th mile 28x10.5's at 3200lbs
70 Challenger RT 440 4-speed 4:10 Dana
http://www.youtube.com/watch?v=VowFy4nDdfI
Re: Slicks Bite, Car Bogs - What to do? [Re: gearjammerdart] #834431
10/20/10 10:34 AM
10/20/10 10:34 AM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
What flywheel are you using and what is the rear gear?
Re: Slicks Bite, Car Bogs - What to do? [Re: Cudajon] #834432
10/20/10 10:42 AM
10/20/10 10:42 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I'm thinking he has the light weight fly wheel in
it and could use the heavier one to carry it through
Re: Slicks Bite, Car Bogs - What to do? [Re: Kudakidd] #834433
10/20/10 11:03 AM
10/20/10 11:03 AM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Is it a 'bog' or just a 'stumble'? Do you have jet extensions on the secondary jets?
If you like drag racing, support your local track.
Re: Slicks Bite, Car Bogs - What to do? [Re: Kudakidd] #834434
10/20/10 12:25 PM
10/20/10 12:25 PM
Mohnton, Pa
DodgeCharger Offline
Mohnton, Pa
I don't know your combo. But when I ran 4 spd I let the clutch fly at 7000 rpm. 4000 seems to low.
Re: Slicks Bite, Car Bogs - What to do? [Re: DodgeCharger] #834435
10/20/10 12:44 PM
10/20/10 12:44 PM
Clinton Twp, Michigan
DerickS Offline
DerickS  Offline
Re: Slicks Bite, Car Bogs - What to do? [Re: DodgeCharger] #834436
10/20/10 12:49 PM
10/20/10 12:49 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
If it bogs, and the timing is right, it needs more fuel.......Carb is too big or it needs more pump shot........I can leave anywhere from 1,500 to 4,500 with my stick car and slicks and it NEVER bogs even when it had 3.54 gears............
BTW, there's a HUGE difference between yanking a motor down because the flywheel is too light or the gear is too high and a bog.......
If you can't handle the truth, you're living a lie.......
Re: Slicks Bite, Car Bogs - What to do? [Re: DodgeCharger] #834437
10/20/10 12:56 PM
10/20/10 12:56 PM
South Lyon, Michigan
6bblRoadrunner Offline
I ran into the same problem when dialing in my car. I launch at 5600 off a 2-step. Turn it up. If it hooks...hang on.
Re: Slicks Bite, Car Bogs - What to do? [Re: DodgeCharger] #834438
10/20/10 01:17 PM
10/20/10 01:17 PM
NJ
JCCuda Offline
JCCuda  Offline
NJ
I'm with DodgeCharger when I ran a stick back in the 80's in my Cuda I would leave between 6&6500.
If your bogging the motor because it doesn't have enough gear or power you need to leave higher or you will start breaking parts from the double hit on the driveline. If it's bogging because of a carb problem or something of that nature fix the problem and then you can figure out how high you need to leave but I'm sure it will need to be higher then 4000. Good Luck!
Re: Slicks Bite, Car Bogs - What to do? [Re: JCCuda] #834439
10/20/10 01:37 PM
10/20/10 01:37 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
what gear? with the 509 you should have 3.91's or better. That cam likes rpms. My buddy had one in 440-6 RR. He'd drop the hammer at 6k and roll. Try going up to 4800. If it still bogs you might need to add some pump shot. Maybe add some timing too. That cam pulls from like 3800-6500.
Re: Slicks Bite, Car Bogs - What to do? [Re: Mr.Yuck] #834440
10/20/10 01:49 PM
10/20/10 01:49 PM
Abilene,Texas
ram87 Offline
ram87  Offline
Abilene,Texas
What about jet extensions? Do you have them? Fuel could be sloshing to the back of the bowl and you might not be picking up fuel until the front comes back down. Make sure you are getting fuel.
Re: Slicks Bite, Car Bogs - What to do? [Re: Big Squeeze] #834441
10/20/10 02:02 PM
10/20/10 02:02 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Re: Slicks Bite, Car Bogs - What to do? [Re: Kudakidd] #834442
10/20/10 02:11 PM
10/20/10 02:11 PM
oh
julian2007 Offline
julian2007  Offline
oh
I ran that combo for years in a 68 fast back cuda 4-speed an all, gear and tire size is most important.I doubt you have an engine issue.I had 4.56 gears and a 29inch tire, if you brought it to 4500 and took it down with the clutch to 4000 when the first amber light and dumped on last amber it would leave perfect every time, you will need a new clutch every year but it will work.I raced mine at Muncie ,IN like that for four years.It went 12.09-12.20 depending on the weather.It takes allot of practice on a car like that but it will work.
If I can find it I think I have a vid of that car leaving.If I find it I will post it.
God made cold beer,good friends,hot ladies and race cars don't spit in his face by pi$$ing and moaning about how life sucks!!!
Re: Slicks Bite, Car Bogs - What to do? [Re: julian2007] #834443
10/20/10 02:59 PM
10/20/10 02:59 PM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
install an automatic - the car will be faster, break fewer parts, and suddenly get more consistent.
Been there - done that - went faster
Slicks [Re: gearjammerdart] #834444
10/20/10 03:06 PM
10/20/10 03:06 PM
Kudakidd Offline OP
Kudakidd  Offline OP
Donald
3.55's in the rear. Tires are 255/60-15. Shifting at 5600 rpm (after I leave the line)
Page 1 of 3 1 2 3
