Re: Billet Specialties Streetlites on A-body
[Re: W5Duster436]
#833860
10/22/10 01:34 PM
10/22/10 01:34 PM
Posts: 2,403 WASHINGTON, PA
11secaarcuda
WASHINGTON, PA
I chose these wheels over the Billet Specialties. They are similar but the spokes are not solid. I liked that look better.
67 Dart GT 340 4 speed 70 AAR Cuda 408 6 barrel 96 Indy Ram original owner 2011 Hemi Durango
[Re: 11secaarcuda]
#833861
10/22/10 01:56 PM
10/22/10 01:56 PM
Posts: 694 Michigan
Super Scamp
I have 15 x 4 with 1 7/8 bs with disk wilwood brakes. with 28" tires..
Just One Man's Opinion
Mopar Mafia Racing
[Re: W5Duster436]
#833862
10/22/10 09:53 PM
10/22/10 09:53 PM
Posts: 47 wv
dakster
wv
Why are you going from DISC to DRUM brakes??
In order to get any aftermarket disc kit (wilwood, strange) you either need to use a 9 or 10" drum spindle. They don't appear to make a kit anymore for the factory disc spindles.
If you have the 73 up disk brake spindles already you can get this kit from Wilwood.
Wilwood # 140-11019 solid rotor # 140-11019-D drilled rotor. Works with the 73-80 disk brake spindles A,B,E,& F body.
http://www.wilwood.com/BrakeKits/BrakeKitListFront.aspx?make=Plymouth&model=Duster&year=1973
[Re: dakster]
#833863
10/22/10 10:45 PM
10/22/10 10:45 PM
Posts: 4,084 Indiana
W5Duster436
Indiana
Thanks but my duster is a '70 with the factory KH disc setup which nobody seems to carry a kit for anymore. I believe at one time they did but not now.
'70 Duster - SDSS 436 W5 4spd (Gone) '71 Dodge D100 '70 Dodge W100
[Re: 11secaarcuda]
#833865
10/23/10 03:17 PM
10/23/10 03:17 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
What are they?
[Re: moparniac]
#833867
10/23/10 07:27 PM
10/23/10 07:27 PM
Posts: 3,420 Toronto
mshred
Toronto
mishred! what is your front tire size? thx
165/80R15
they are cheapy 60 bucks a side Nexen radials
[Re: 11secaarcuda]
#833869
10/25/10 08:27 PM
10/25/10 08:27 PM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
What are they?
Centerline Competition Series Split Spoke
Billet Specialties wheel centers are made by Centerline BTW.. So, if you get a Centerline you get the same wheel for less money...
I have this wheel on my car.
Chris..
[Re: Chris'sBarracuda]
#833874
10/29/10 09:47 PM
10/29/10 09:47 PM
W5Duster436
Indiana
okay, anyone running the 15x10 rears with 5.5BS or more and disc brakes? Summit doesn't mention on their site there is an issue with 5.5 or more backspace and calipers. I finally found it on Billet Specialties website. I am really upset now. I am also wondering if I'll find out the 15x4 2.25BS won't work with the wilwood front kit too!
