Welding up advance slots in M.P dist... #833351
10/19/10 12:42 AM
10/19/10 12:42 AM
Sask, Can.
72demon416 Offline OP
Sask, Can.
I'm about to go out and weld them up but then I got thinking about soldering them instead... It would be way easier to work with if tweaking is req'd- but is it too soft?
Re: Welding up advance slots in M.P dist... [Re: 72demon416] #833352
10/19/10 12:46 AM
10/19/10 12:46 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
WELD THEM
take the distributer apart
two ligth spot welds , so you dont warp the plate
did this on my tach drive long time ago
1.39 9.85 - 137 mph
Re: Welding up advance slots in M.P dist... [Re: Ari440] #833353
10/19/10 12:50 AM
10/19/10 12:50 AM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
What happens if you warp the plate?
I welded mine back in the spring and the idle quality hasnt been right since.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Welding up advance slots in M.P dist... [Re: Ari440] #833354
10/19/10 01:18 AM
10/19/10 01:18 AM
Sask, Can.
Sask, Can.
I see there is numbers 13L & 13R stamped into the plate- does that have any significant meaning?
Re: Welding up advance slots in M.P dist... [Re: 72demon416] #833355
10/19/10 01:28 AM
10/19/10 01:28 AM
Wpg, Mb, Canada
six-barrel Offline
six-barrel  Offline
Wpg, Mb, Canada
Don at FBO sells a plate with 4 mech limit slots. No welding required. The 13 should indicate 13x2=26 degrees mechanical timing
Re: Welding up advance slots in M.P dist... [Re: six-barrel] #833356
10/19/10 02:02 AM
10/19/10 02:02 AM
Sask, Can.
Sask, Can.
Well that certainly makes sense- thanks!
Now.. Knowing that little tidbit I'm just a little more confused as to what is going on in my dizzy because I set my total to 32 @ 2600 and when I checked the initial it was @ 8
So... I figure I'll bump it to 18 initial but the total only went up to 38
I'm not sure whether there is a reason for that and I am uneducated in it's function or if there is a problem there?
Either way, the slots are welded and it's going back together and we'll see how this works out.
Re: Welding up advance slots in M.P dist... [Re: 72demon416] #833357
10/19/10 02:49 AM
10/19/10 02:49 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
try JB weld
Re: Welding up advance slots in M.P dist... [Re: ademon] #833358
10/19/10 02:59 AM
10/19/10 02:59 AM
Sask, Can.
Sask, Can.
Too late- I already welded it up... good idea though
Re: Welding up advance slots in M.P dist... [Re: 72demon416] #833359
10/19/10 03:11 AM
10/19/10 03:11 AM
Melbourne.....Oz-land
Moparmal Offline
Moparmal  Offline
Make sure the slots are allowing the weight locator pins to traverse smoothly. Welding may have distorted them.
As a rough guide and in a factory Mopar dist :
Advance slot distances:
.475 th = 15 deg in the plate
.338 th = 9 deg in the plate
Re: Welding up advance slots in M.P dist... [Re: Moparmal] #833360
10/19/10 06:03 AM
10/19/10 06:03 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
Re: Welding up advance slots in M.P dist... [Re: 493_DART] #833361
10/19/10 07:55 AM
10/19/10 07:55 AM
Az
Crizila Offline
Crizila  Offline
Az
i used this in my MP dist.
http://www.amazon.com/Mallory-29014-Advance-Curve-Change/dp/B000BWE38W
works perfect.
What are them long red plastic things in the kit?
Fastest 300
Re: Welding up advance slots in M.P dist... [Re: 72demon416] #833362
10/19/10 08:18 AM
10/19/10 08:18 AM
Az
Crizila Offline
Crizila  Offline
Az
If you have access to a gas welder brazing the slots works well also without putting too much heat to it. Also, keep in mind that most electronic distributors like the Mopar unit will retard about 1 degree for every 1000rpm over about 4K - and something slightly less than that starting around 3500, so when you are playing with advance curves / totals, always use the same rpm when setting the total timing. I usually like to use the 3 to 3500 rpm range ( very few circumstances where you want the curve to be past 3K ). That way I am sure all the mechanical is in, and I am staying out of the "electronic retard" range.
Fastest 300
Re: Welding up advance slots in M.P dist... [Re: ademon] #833363
10/19/10 09:40 AM
10/19/10 09:40 AM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
try JB weld
I did this to my dist and it lasted about 1k miles before it fell out.....
Re: Welding up advance slots in M.P dist... [Re: Von] #833364
10/19/10 10:21 AM
10/19/10 10:21 AM
Sask, Can.
Sask, Can.
I just put a couple of small 3 mm long tack welds in the center of the slots, the allowable travel of the pins is 6mm. My welds don't touch the sides and there was not nearly enough heat for distortion so as long as I welded up enough travel it should be all good
Re: Welding up advance slots in M.P dist... [Re: six-barrel] #833365
10/19/10 12:26 PM
10/19/10 12:26 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Any one have contact info for Don @ FBO?
Re: Welding up advance slots in M.P dist... [Re: Dabee] #833366
10/19/10 12:44 PM
10/19/10 12:44 PM
Cambridge, Ontario, Canada
CUDAJAS Offline
CUDAJAS  Offline
try www.4secondsflat.com
contact info is on the website.
Jason
Re: Welding up advance slots in M.P dist... [Re: Dabee] #833367
10/19/10 01:48 PM
10/19/10 01:48 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Good Luck......
Re: Welding up advance slots in M.P dist... [Re: Crizila] #833368
10/19/10 05:21 PM
10/19/10 05:21 PM
Airdrie, AB
Mills Offline
Mills  Offline
Airdrie, AB
works perfect.
Current MP distributors are fully adjustable (and made by Mallory) - no welding required. Those "Long Red Plastic things" are guages that you insert into the distributor so you can change the amount of mechanical advance (i.e. slot length) w/o taking the distributor apart.
1967 Satellite, CNC Eddy Headed 500ci Street Mauler
(Dyno'ed @ 600 HP / 650 ft-lbs)
2016 Challenger Hellcat - Holy Hell
2012 Hemi Ram Sport Crew Cab
2011 Avenger, Pentastar V-6
2007 SRT-8 Charger (Dyno'ed @ 470 RWHP)
1986 Caravelle, 318, aka "Rosco", Back Road Burner!
ALL Black...Bad Boys always wear Black!
Re: Welding up advance slots in M.P dist... [Re: Crizila] #833369
10/19/10 05:22 PM
10/19/10 05:22 PM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
works perfect.
you stick them in the slot while you adjust. there are diff degrees. They are surprisingly accurate .
Re: Welding up advance slots in M.P dist... [Re: 493_DART] #833370
10/19/10 06:50 PM
10/19/10 06:50 PM
Az
Crizila Offline
Crizila  Offline
Az
works perfect.
ok, thanks.
Fastest 300
