5.7 hemi into 73 Charger.... I need some information #832894
10/18/10 03:12 PM
10/18/10 03:12 PM
Maryland
340_Dart Offline OP
340_Dart  Offline OP
Maryland
Anyone put a new style hemi into an old mopar? What all is involved? I think i read somewhere that a smallblock 727 or 904 will bolt up to the hemi. What about converter? motor mounts? electrical issues? We're planning on making the hemi caburated if we do the swap, but what about spark and other hemi sensors? thanks- Andy
Re: 5.7 hemi into 73 Charger.... I need some information [Re: 340_Dart] #832895
10/18/10 03:44 PM
10/18/10 03:44 PM
Oak Grove, MN
lowflyingdart Offline
Oak Grove, MN
Mopar makes a flexplate for the converter, use a 904 trans. Starters are a small issue. The Rob Mc starter fits but has issues of it's own. There is a timing cover that will allow you to use a distributor, but I would consider using FI.
Larry
"I have not failed. I've just found 10,000 ways that won't work." Thomas A. Edison
Re: 5.7 hemi into 73 Charger.... I need some information [Re: lowflyingdart] #832896
10/18/10 04:07 PM
10/18/10 04:07 PM
sweden
sshemi Offline
sshemi  Offline
sweden
im also planning this.
Msd have something called the Hemi6 and with a harness from msd you have spark.
And offcourse you need headers and a oil pan(if you dont build your own.
I leaning towards a carb intake from xv motorsports simply cause they are cheapest.
I also plan on doing a custom cam cover simply cause its so darn ugly.
TTI have the motormounts i think.
As for flexplate you can use the stock 5.7 hemi plate if you just cut of the starter teeths.
As for upgrades for me it will be headers, 750 carb, some porting some wild hughes cam ,just to get the idle i like ,with matching springs.
I will also use forged pistons from mopar ~200$ and some aftermarket rods since i read somewhere that you will need to replace the rod bolts anyway.
And then some spray on it.
Aldough i have 3 more builds before this so i guess you could say im in the early stages.
Re: 5.7 hemi into 73 Charger.... I need some information [Re: 340_Dart] #832897
10/19/10 10:33 AM
10/19/10 10:33 AM
NW PA
V10nacuda Offline
V10nacuda  Offline
NW PA
I put a 6.1 into a 73 D100..
IGNITION: FAST
FUEL: Aeromotive
THROTTLE BODY: SLP
HEADERS: SLightly modified SRT Grand Cherokee (There are some places making exact fit ones for cars now)
MOTOR MOUNT: E-bag....But for you I think there are people making them for cars.
TRANSMISSION: 727 with a Mopar flex Plate
(Dont waste your money on that stupid no functioning spacer kit that XV sells!!!!! JUNK)
CONVERTER: 10" TCI 3800 stall that had HUNDREDS of passes in my old cuda
Fun to drive
Went 12.20, dont remember the MPH but it weighed 3600 WIthout the tail gate...
V10
Re: 5.7 hemi into 73 Charger.... I need some information [Re: lowflyingdart] #832898
10/19/10 10:47 AM
10/19/10 10:47 AM
S.E. Michigan
ZIPPY Online content
ZIPPY  Online Content
S.E. Michigan
The Rob MC starter was used on the Challenger drag pak because the steering column and starter want to occupy the same area. ATI has a nice starter option for that vehicle now, also.....
In most older trucks and musclcars where the steering column is not a problem, a regular Chrysler mini starter fits/works fine. Ask for one for a 1994 Ram 1500 with a 5.9 magnum
Rich H.
Esse Quam Videri
Re: 5.7 hemi into 73 Charger.... I need some information [Re: ZIPPY] #832899
10/19/10 01:28 PM
10/19/10 01:28 PM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
Here's mine, 6.1 SRT8 Hemi in a 70 Road Runner. I wenth the motor plate route. I'm also using a Turbo 400 with a JW Ultrabell & Mopar Lite Weight Starter. I made my own headers & used a modified Milodon Oil Pan. I'm also using the FAST ignition controller. I should have it ready for start up this weekend.
Re: 5.7 hemi into 73 Charger.... I need some information [Re: STEFF] #832900
10/19/10 05:23 PM
10/19/10 05:23 PM
Home
SRT6776 Offline
I hate internal combustion engines!
SRT6776  Offline
Home
Some REALLY cool 6.1L swaps in the project forum
71 Roadrunner SRT8
https://board.moparts.org/ubbthreads/show...e=0#Post5752978
4 door Belvedere SRT8
https://board.moparts.org/ubbthreads/show...e=0&fpart=1
Re: 5.7 hemi into 73 Charger.... I need some information [Re: STEFF] #832901
10/19/10 05:24 PM
10/19/10 05:24 PM
Airdrie, AB
Mills Offline
Mills  Offline
Airdrie, AB
Both Hot Rod and Car Craft have pretty good technical articles available online in the archives about new Hemi in old Muscle swaps
1967 Satellite, CNC Eddy Headed 500ci Street Mauler
(Dyno'ed @ 600 HP / 650 ft-lbs)
2016 Challenger Hellcat - Holy Hell
2012 Hemi Ram Sport Crew Cab
2011 Avenger, Pentastar V-6
2007 SRT-8 Charger (Dyno'ed @ 470 RWHP)
1986 Caravelle, 318, aka "Rosco", Back Road Burner!
ALL Black...Bad Boys always wear Black!
