Re: How fast are you guys going with budget 440?
[Re: Quicktree]
#832458
10/31/10 08:24 PM
10/31/10 08:24 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
A couple of mine: Rebuilt 440 with six pack slugs, stock 906 heads (milled to 80cc) orig Eddy torker, 750 Holley, Crower hyd cam 240-ish @ 050, 4.30's and a WAY too loose J-converter with 4.30's: 11.41 @ 117 in a 69 Dart
.030 over 440 with 2266 TRW out of the deck. 255-ish cfm 906 heads, R280 roller, M1, 1050 Dom, 8" converter, 4.86's, with a back-half and ladder bars...14x32's: 10.28 @ 128 best in a 73 Cuda.
A buddy's from years ago that's still one of may favs: STOCK 78 short block...pistons down .070. STOCK 915 heads, MP .484 cam, Eddy RPM, 750 Holley, OEM 11" Hemi converter, 4.56's: 12.48 @ 109 best in a 3800# 65 Sat WAGON!!!!
[Re: cudadoug]
#832459
10/31/10 09:07 PM
10/31/10 09:07 PM
fast68plymouth
So. Burlington, Vt.
-448" -Sealed Power forged flat tops(bought in 1981) .055 down the hole -actual CR of 9.7:1 -LY rods with the old MP bolts -.020/.020 steel crank -old DC .510/292 cam -bowl blended big valve 906's(later tested and flowed 239cfm) -Torker II, OOTB -ported annular 850 Holley(905cfm) -2" Hookers -4.10 gear -10" GER converter(yup....GER) -29.5X10.5 M/T slicks -SS springs -3600lb race weight all steel 68 Satellite, full interior
11.40's @ 119
swap to Dynamic 9" race converter(4900 flash) and 4.56 gears, went 11.21 @ 122
port heads to flow mid-260's, add .650 lift UD roller cam and HS rockers, new roller springs, etc, went a best of 10.61 @ 126+ at 3670lbs(added roll bar).
the extra head work and roller cam now had the converter flashing to 5300. best 60' was 1.46. this was circa 1995.
[Re: tboomer]
#832461
10/31/10 11:37 PM
10/31/10 11:37 PM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
73DartSport owns my old 73 Sport now, I found a smokin deal on a low deck 451 short block(400 block with 440 crank), stuck some stock Eddy heads on it and the MP 590 purpleshaft and went 10.20 with a Dominator and 2" headers in a 3050# car with driver. I had the heads ported and went 10.00's with a 9.96 in great air, then added a tunnel ram and went 9.90's with a best of 9.89. I never dreamed it would run like that, only hoped for 10.50's when finishing the car. Compression is about 11.2:1, pump gas on the street, mix of pump gas/race gas at the track, no transbrake, no power adders, fun car on the street, even has a quiet X-pipe exhaust system. New owner went 9.77 last month!
[Re: viperblue72]
#832465
05/07/12 06:57 AM
05/07/12 06:57 AM
Posts: 3,210 robin hood country
deaks
robin hood country
Here's mine then 440 RB, J E domes 12.7.1, .590 cam, MCH RPM's milled to 76 cc, victor intake, holley 950 hp, 3200# with me, 727 with 4800-5000 ultimate converter, dana 60 4.56 gears, SS springs, hoosier 31x10.5x15 slicks. best times and speed in sig. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: Joes66dart]
#832467
05/07/12 10:46 AM
05/07/12 10:46 AM
Posts: 336 Creston, Iowa
340man4ever
Creston, Iowa
Mine:
1974 Dodge Dart 2dr 3300lbs at the line.
440 zero decked w/flat top pistons. Ported 915 heads flow 268/207 peak. 11.25:1 Compression
Mopar 590 Solid Cam
850 HP carb, M1 intake, McCandless/ ProParts Headers
727 trans w/ Dynamic 9.5 converter (hi gear flashes 5100) 4.30 gear, 30x9 slicks
Footbrake @ 1800rpm shift at 6200
Bests so far:
10.77 @ 122.8 mph 1/4
1.47 60 ft 6.80 @ 99.79 1/8th
Curator at Adams County Speed Shop
[Re: 340man4ever]
#832468
05/07/12 11:18 AM
05/07/12 11:18 AM
Posts: 485 Central California
MoParFish
Central California
Stock steel crank Stock LY rods & rod bolts 2355 TRW Flat Tops Ported 452s milled to 80cc 10.7:1 comp??? .575 262/262 solid roller with 1.6 rockers Victor manifold with 850 Holley B Body 3825lb Car & Driver [Email]11.54@118[/Email] and with 200 shot of spray just went [Email]10.57@126[/Email] Wonder how long the bottom end will live Wow! Just noticed how old this thread is...
[Re: 340man4ever]
#832470
05/07/12 06:18 PM
05/07/12 06:18 PM
Posts: 460 Oklahoma
VoodooCLD
Oklahoma
Mine:
Mopar 590 Solid Cam
Bests so far:
What fuel do you run in that thing?
