Re: Drag race front end tricks
[Re: Big Squeeze]
#832387
10/18/10 12:48 AM
10/18/10 12:48 AM
Triple Threat
Renton Washington
Stock front suspension, 6 cylinder bars, rubber bushings. Calvert 90/10 front shocks, caltracs and monos rear. I have just at 4.5" front travel with a 25" tall front tire. Here's the car at rest for comparison:
[Re: Big Squeeze]
#832388
10/18/10 01:41 PM
10/18/10 01:41 PM
Posts: 1,409 Ont. Canada
10.90 Racer
super street
super street
Ont. Canada
What can you do to a 69 A body to loosen the front end and have 5" of travel??
Has anyone gone smaller then the .810 Drag bar???
I've just used the 6 cylider bars........Just Supsension urethane lower control arm bushings......heim joint strut rods and heim joint tubular upper control arms from RMS........Cal-Trac front shocks.........and as tall of a front tire that will fit......
Big Squeeze I have been reading some of your posts. Good info. I'm going to use an adjustable strut rod and replace my lca bushings with poly ones. I was thinking about the FFI greesable pins and bushings.
[Re: justinp61]
#832390
10/18/10 04:15 PM
10/18/10 04:15 PM
Posts: 42 England
pete walton
England
My ole race car has 6cyl torsion bars and comp engineering three way shocks up front.Not to sure how much travel but there is a lot .I think this is exagerated by the big ole skins on the rear.Rear springs are 2800lbs super stocks with strange 20 adjustables...Car weighs 2780lbs with me...
[Re: 10.90 Racer]
#832391
10/18/10 05:29 PM
10/18/10 05:29 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
RIP Monte Smith
[Re: pete walton]
#832393
10/18/10 08:06 PM
10/18/10 08:06 PM
Posts: 1,476 Oh
RacerGofKGB
Got The Big One
Got The Big One
Oh
That thing looks BAD @ZZ. Love it.
