340 engine #832374
10/17/10 09:34 PM
10/17/10 09:34 PM
ohio
bigblockrik Offline OP
ohio
I just bought a 59 rambler american 2d wagon.I have a 340 block and crank rods heads.What cam and intake would you run in it.I am going to drive it but i want to tow a trailer with it also.Also want a overdrive in it too what trans do i need ?
Re: 340 engine [Re: bigblockrik] #832375
10/17/10 09:48 PM
10/17/10 09:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Well you want the same trans I just bought yesterday,
a 88-92 van or truck with OD that has a 2 or 3 pin
connector(this isnt the neutral safety switch) a small
connector near the shifter... I'll take a pic of
the trans tomorrow for ya.... cam wise you want a
low duration for torque and a dual plane intake like
a rpm air gap
EDIT
Read my post "I need Idea's" and should should figure
out the trans issue
