Punctured a new slick....now what? #832038
10/17/10 05:34 PM
10/17/10 05:34 PM
Tampa Florida
dc426 Offline OP
gotta keep'm separated
dc426  Offline OP
Tampa Florida
This blows. They only have about 23 passes on them and the right rear got punctured last night. Can it be safely patched from the inside or am I going to have to buy tubes now? Can I just use a tube for this side?
DC
Re: Punctured a new slick....now what? [Re: dc426] #832039
10/17/10 05:43 PM
10/17/10 05:43 PM
Q
Quicktree Offline
Quicktree  Offline
Q
how bad is it? I wouldn't tube one side, both or nothing. I have patched slicks in the past and it held but probably not the safest thing in the world.
Re: Punctured a new slick....now what? [Re: Quicktree] #832040
10/17/10 05:46 PM
10/17/10 05:46 PM
Tampa Florida
dc426 Offline OP
dc426  Offline OP
Tampa Florida
I would say it's a pretty good puncture (what ever that means). I guess I could tube them until the next set. This sucks!
I would like to hear more more about trying to patch it.
Re: Punctured a new slick....now what? [Re: dc426] #832041
10/17/10 05:48 PM
10/17/10 05:48 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I took mine o a tire shop and had it vulcanized(if thats how you spell it )
Re: Punctured a new slick....now what? [Re: Quicktree] #832042
10/17/10 06:08 PM
10/17/10 06:08 PM
reynoldsburg,ohio
poppaj Offline
poppaj  Offline
reynoldsburg,ohio
Believe it or not most class racers will simply put a plug in them. You wouldn't think so but it works quite well.
AA/NSS 65'Coronet "Whompin Wedge"
Pop & Son Performance 557" B-1 power
John Holt Chassis
Re: Punctured a new slick....now what? [Re: Quicktree] #832043
10/17/10 06:08 PM
10/17/10 06:08 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
They make a tire patch that looks like a golf tee from a driving range. Lots of them being used from what I have been told.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Punctured a new slick....now what? [Re: dc426] #832044
10/17/10 06:12 PM
10/17/10 06:12 PM
Lehigh Acres, Florida
rickstershemi Offline
It sucks, but just get a new one Chris
Rickster
Re: Punctured a new slick....now what? [Re: pittsburghracer] #832045
10/17/10 06:47 PM
10/17/10 06:47 PM
Az
Crizila Offline
Crizila  Offline
Az
It's called a patch plug. They work great and you won't have a problem using one. Much better than just the plug. I'd put one in even if I decided to use tubes.
Fastest 300
Re: Punctured a new slick....now what? [Re: Crizila] #832046
10/17/10 07:00 PM
10/17/10 07:00 PM
PA.
"Little"John
"Little"John
PA.
Thanks. I couldn't remember the name of it but almost any trucking company or tire dealer should be able to fix him up.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Punctured a new slick....now what? [Re: pittsburghracer] #832047
10/17/10 07:17 PM
10/17/10 07:17 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I've run a plug, no problems; but I also run tubes.
Re: Punctured a new slick....now what? [Re: topside] #832048
10/17/10 07:22 PM
10/17/10 07:22 PM
Western,Pa.
MagnumDartSport Offline
Western,Pa.
I've plugged my last three(!!!) sets without ANY problems.I went over 25 yrs without a flat,I guess things have evened out!!
Re: Punctured a new slick....now what? [Re: MagnumDartSport] #832049
10/17/10 07:58 PM
10/17/10 07:58 PM
Hemiroid Offline
Hemiroid  Offline
new tire: $200
patching old tire: $20
Not ending up on your roof because you were a cheap a$$ and tried to reuse a screwed up tire to save a few bucks: PRICELESS!!!!
Buy a new slick and move on. JMHO ofcourse
Re: Punctured a new slick....now what? [Re: Hemiroid] #832050
10/17/10 08:04 PM
10/17/10 08:04 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
IMHO if done correctly I see nothing wrong with fixing it but then again I do not have $$$$$ to burn so I do what I have to.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Punctured a new slick....now what? [Re: Hemiroid] #832051
10/17/10 08:05 PM
10/17/10 08:05 PM
Ont. Canada
10.90 Racer Offline
super street
10.90 Racer  Offline
super street
Ont. Canada
I have plugged them for years...no issues!!!! I have even plugged them between rounds.
Re: Punctured a new slick....now what? [Re: 10.90 Racer] #832052
10/17/10 08:22 PM
10/17/10 08:22 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
I had gone for years with out a flat, but that changed last year. I had 5 flats in less than 1 year. 3 at Bristol!!!! Front tire at English Mountian, the rest were rear. I ran tubes in the rear until this set, which I mounted tubeless. I put the new tires on and ran 4 passes at Pinks All Out, then went to Clay City and between 1st & 2nd round sunday (15th pass on new slicks), got a rock cut. Plugged it and went 10.406/127.xx on next pass. I will patch it before I race again though.
I hate flats.
Brian Dunnigan
Re: Punctured a new slick....now what? [Re: dc426] #832053
10/17/10 08:27 PM
10/17/10 08:27 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I'd use a patch plug and be done with it.It will work just fine.
Nautilus Racing-
Re: Punctured a new slick....now what? [Re: Chris2581] #832054
10/17/10 08:36 PM
10/17/10 08:36 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
I got a long piece of copper wire in a slick at Sunshine and used the "glue on" type patch that goes inside the slick. Still good over a year later.
IIRC, you grind the area around the puncture till its smooth. Apply the glue/patch then light on fire!
Re: Punctured a new slick....now what? [Re: dc426] #832055
10/17/10 11:04 PM
10/17/10 11:04 PM
Cab_Burge Online work
Cab_Burge  Online Work
If your running race tubes(natural rubber) now take it to a good tire shop, preferably one that does large truck and heavy equiptment sales also, and have them fix it They will probally patch the tube and look at the tire to see if it is damaged enough to nead a boot or patch on the inside so it won't cause another hole in the tube Make sure they inspect the inside of the tire If your running the slicks tubeless, like I do, you can have the tire patch on the inside or use a plug as long as it is not torn up on the inside of the tire so bad that the plug won't hold air. If it is not a simple puncture in the tire you can still have it repair with patch on the inside or a boot your decision One of the other comments already made where about class racers keeping a plug kit in there tools, I know several class racers that have set SS and stock NHRA class records with plugged tires because they where limited on time to make the back up run at a divisional race when they had the flat
Re: Punctured a new slick....now what? [Re: Cab_Burge] #832056
10/18/10 12:04 AM
10/18/10 12:04 AM
Pound, Va
Chris Vanover Offline
Pound, Va
i've been 5.6's in the 1/8th with plugs in both rear tires..never a problem
Re: Punctured a new slick....now what? [Re: Cab_Burge] #832057
10/18/10 12:07 AM
10/18/10 12:07 AM
corpus christi tex
Cheatham Offline
Cheatham  Offline
corpus christi tex
something to think about is that the slicks do have an oil in the rubber and may make using a patch difficult, id go with tubes if the tire is not torn or not too big of a puncture
