69 B-body radiator inlet and outlet location #831381
10/16/10 10:43 PM
10/16/10 10:43 PM
California
Drip Offline OP
Drip  Offline OP
California
I have a 69 Sat that was a 6 cyl car and I am putting a 440 in it. looking to put in an after market radiator. Were should the inlet and outlet tubes in the radiator be. I will be using a water pump housing from a 69 440.
thanks
Re: 69 B-body radiator inlet and outlet location [Re: Drip] #831382
10/16/10 10:53 PM
10/16/10 10:53 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
Bottom driver side.Top passener side
Re: 69 B-body radiator inlet and outlet location [Re: gtx69] #831383
10/17/10 02:04 AM
10/17/10 02:04 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Cast crank 440s need the lower outlet on the passenger side, forged crank on the drivers side,,
Check your new motor to determine outlet position.
Re: 69 B-body radiator inlet and outlet location [Re: sthemi] #831384
10/17/10 02:19 AM
10/17/10 02:19 AM
California
Drip Offline OP
Drip  Offline OP
California
I have a cast crank now but will be going to a forged crank in the future. any suggestions.
Re: 69 B-body radiator inlet and outlet location [Re: Drip] #831385
10/17/10 02:54 AM
10/17/10 02:54 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
The waterpump outlet determines the radiator hose location.. When you swap from cast to forged crank if you keep the waterpump housing you were already running the hose location doesn't change..
69 waterpump is drivers lower, passenger upper as was previously mentioned..
Re: 69 B-body radiator inlet and outlet location [Re: 1_WILD_RT] #831386
10/17/10 03:04 AM
10/17/10 03:04 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Hmmmmm....
Here's the 22" 053 radiator which was standard with 69 440 HP automatics.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: 69 B-body radiator inlet and outlet location [Re: 69CoronetRT] #831387
10/17/10 03:57 AM
10/17/10 03:57 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Well yeah the 22" is drivers top & bottom but the hose connections on the engine remain the same & if I were selecting a radiator for a conversion you can be sure it won't be a 22"..
Re: 69 B-body radiator inlet and outlet location [Re: 1_WILD_RT] #831388
10/18/10 01:48 AM
10/18/10 01:48 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
I agree...they do not work the best on hot summer days when you are stuck in traffic. However, I wouldn't cut the support to install a 26" either.
Seeking:
Re: 69 B-body radiator inlet and outlet location [Re: 69CoronetRT] #831389
10/18/10 04:44 AM
10/18/10 04:44 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I would be hesitant to change a radiator support on a #s car but the car in question is a 6 cylinder car receiving a 440...
Re: 69 B-body radiator inlet and outlet location [Re: 1_WILD_RT] #831390
10/19/10 08:49 PM
10/19/10 08:49 PM
NJ
rth Offline
rth  Offline
NJ
not meaning to hijack but why do some of you guys think a 22"rad wont keep a 440 cool.thats how lots of them came when new and used everyday.with a proper system it works fine.
Re: 69 B-body radiator inlet and outlet location [Re: rth] #831391
10/19/10 09:00 PM
10/19/10 09:00 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
depends how things are set up. I have a 22" aftermarket aluminum down flow rad that mimics the stock 22" rad. It cools a 658HP 472 Hemi just fine BUT I use a solid 6 blade 16" fan, a shroud, 10.3 to 1 compression, 180 degree milodon thermostate, 50/50 mix Zerex antifreeze and stock ratio pulleys. It never got over 190 in the hottest humidest days. I also have all the hood seals and gravel pan in place. It's also a 4 speed. Proper engine clearances are important. A fresh re-build may run a little warmer until things loosen up. Enough ignition timing and proper fuel mixture are important too.
If you run more compression, or use underdrive pulleys, or go on the high side of the anti freeze mix, run with no shroud, or some of the flex fans out there, you could run into trouble.
Re: 69 B-body radiator inlet and outlet location [Re: rth] #831392
10/19/10 09:20 PM
10/19/10 09:20 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Mostly from experience
Seeking:
Re: 69 B-body radiator inlet and outlet location [Re: 69CoronetRT] #831393
10/19/10 11:14 PM
10/19/10 11:14 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Amen brother...
Re: 69 B-body radiator inlet and outlet location [Re: 1_WILD_RT] #831394
10/20/10 09:12 AM
10/20/10 09:12 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I run a 22 in my 65 and my kid has the same in his 62.My 440 has 12.5 pistons stainless flex fan shriud under drive pulleys.Mine runs at 180 all day even when its 90s out.My rad is OE 65 never been touched.My kids was recored to 4 core for his 413 with under drive pulleys and no shroud.Still runs 180 and he puts probally 5 K a year on his.Mine gets about 2K a year.Rocky
Chrysler Firepower
Re: 69 B-body radiator inlet and outlet location [Re: sthemi] #831395
10/20/10 09:35 AM
10/20/10 09:35 AM
Anderson, IN
1969RR Offline
1969RR  Offline
Anderson, IN
Hello! Fairly new to Mopar engines, so don't laugh....but, why does the crank make a difference? I honestly don't know why. Thanks!
Re: 69 B-body radiator inlet and outlet location [Re: 1969RR] #831396
10/20/10 12:02 PM
10/20/10 12:02 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
Crank doesn't matter.Depends on what water pump housing you have.Lower outlet be could me on the left or right your your choice which one you want to use.
Re: 69 B-body radiator inlet and outlet location [Re: therocks] #831397
10/20/10 01:34 PM
10/20/10 01:34 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
And you average summer ambient temperature runs where??
Never mind I looked it up..
Apr Temp 38 to 62 F
Jul Temp 61 to 86 F
Oct Temp 41 to 65 F
Talk to me when you have a week straight over 105..
Re: 69 B-body radiator inlet and outlet location [Re: 1_WILD_RT] #831398
10/20/10 02:21 PM
10/20/10 02:21 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Apr Temp 38 to 62 F
Jul Temp 61 to 86 F
Oct Temp 41 to 65 F
or with humidity and a 110 heat index and in traffic.
Seeking:
