Re: Pinion Centered on a street car?
[Re: buildanother]
#831347
10/17/10 08:54 AM
10/17/10 08:54 AM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
I would leave it offset to the pass side like the crank and tunnel are now.
I agree or your wheels will also be off set to one side unless you machine the housing and shorten one axle.
[Re: MoparforLife]
#831348
10/17/10 06:10 PM
10/17/10 06:10 PM
Posts: 699 Cooperstown, NY
jrlegacy23
Cooperstown, NY
I am cutting down an axle and putting it in the car. I am just looking at different options, like the Ferd 8.8 and cutting the long side axle to the short side length, which will then center the pinion side to side.
[color:"#00FF00"]68 Fastback Barracuda with some stuff[/color]
[Re: stumpy]
#831350
10/17/10 06:23 PM
10/17/10 06:23 PM
jrlegacy23
Cooperstown, NY
It will not rub at all. It only moves the pinion over 1 3/8" to the drivers side.
[Re: jrlegacy23]
#831352
10/17/10 06:49 PM
10/17/10 06:49 PM
RapidRobert
w the furd pinion offset being (I'm sure)different from a Mopar I would shorten one side (axle/housing) so the pinion CL is offset the same amt side to side in relation to the springs/body as a Mopar one is
