Page 2 of 4 1 2 3 4
Re: Crew Cab Oil Burner [Re: MoparMike23] #831130
10/22/10 07:41 PM
10/22/10 07:41 PM
Sparks, Nevada
MoparMike23 Offline OP
Sparks, Nevada
#2
1969 Superbee 440-6
1977 D-150 Adventurer
2000 Jeep TJ
2018 Challenger Scat Pack Shaker
2019 Ram 2500 CTD
Re: Crew Cab Oil Burner [Re: MoparMike23] #831131
10/22/10 07:42 PM
10/22/10 07:42 PM
Sparks, Nevada
Sparks, Nevada
Final stop, Pick and Pull.
1969 Superbee 440-6
2000 Jeep TJ
2019 Ram 2500 CTD
Re: Crew Cab Oil Burner [Re: MoparMike23] #831132
10/22/10 07:48 PM
10/22/10 07:48 PM
CA, Proprietor; The "PALOMINO"...
dynotune440 Offline
dynotune440  Offline
I hope you pulled the front suspension out of it????
there were still some good parts on it....
Dinuba, California, Home of the PALOMINO ranch and 440 truck farm, where dodge trucks have a home. Have Four 1979 dodge PALOMINO trucks now.
Re: Crew Cab Oil Burner [Re: dynotune440] #831133
10/22/10 08:56 PM
10/22/10 08:56 PM
Sparks, Nevada
Sparks, Nevada
I left the A arms and spindles with concern they could have been damaged from the collision. PNP did give me 2 bills for what was left.
1969 Superbee 440-6
2000 Jeep TJ
2019 Ram 2500 CTD
Re: Crew Cab Oil Burner [Re: MoparMike23] #831134
11/08/10 12:46 PM
11/08/10 12:46 PM
Sparks, Nevada
Sparks, Nevada
Finally was able to spend some time on the truck. I pulled the old stuff, including the trans cross member, cleaned up the Cummins, and stuffed it in. I put the Cummins in with the tranny attached. Yeah, I know, One pissed off engine hoist. Because the Cummins is tall, I had to undo the front cab mounts and lift the cab a few inches. Also remember to leave the motor mounts loose on the brackets so you can get them lined up on the frame. This really was very simple. It was like the truck was made for the Diesel. Now I need to finish hooking up everything.
BTW- I had posted a Wanted Ad regarding the parts I still need. I had a bunch of reply's from overseas (Italy)and fear they are a scam. Beware, if you post ad's on Moparts, some of the reply's might no be legit.
Mike
1969 Superbee 440-6
2000 Jeep TJ
2019 Ram 2500 CTD
Re: Crew Cab Oil Burner [Re: MoparMike23] #831135
11/08/10 12:49 PM
11/08/10 12:49 PM
Sparks, Nevada
Sparks, Nevada
I'm now the proud owner of a Cummins powered truck. Just not running yet.
1969 Superbee 440-6
2000 Jeep TJ
2019 Ram 2500 CTD
Re: Crew Cab Oil Burner [Re: MoparMike23] #831136
12/25/10 12:36 AM
12/25/10 12:36 AM
Sparks, Nevada
Sparks, Nevada
Merry Christmas to me. I picked up my drive shaft today and it came out of the garage under its own power. Sorry I haven't updated this but its hard enough to get the time to just work on it. So, everything has installed with ease. The tranny cross member had to be moved back a few inches. I had to extend everything underneath to compensate for the added length, but thats was a given. The hardest task was the core support. I converted a gas core support because I'm too cheap. I gotta say, overall, the job wasn't complicated, just a lot of labor. Now I'm waiting on the radiator and fan components.
Mike
1969 Superbee 440-6
2000 Jeep TJ
2019 Ram 2500 CTD
Re: Crew Cab Oil Burner [Re: MoparMike23] #831137
12/25/10 12:37 AM
12/25/10 12:37 AM
Sparks, Nevada
Sparks, Nevada
Almost there....
1969 Superbee 440-6
2000 Jeep TJ
2019 Ram 2500 CTD
Re: Crew Cab Oil Burner [Re: MoparMike23] #831138
12/25/10 02:25 AM
12/25/10 02:25 AM
dynotune440 Offline
dynotune440  Offline
cool deal Mike....
Re: Crew Cab Oil Burner [Re: dynotune440] #831139
12/25/10 10:40 AM
12/25/10 10:40 AM
Canada
Lugnutz Offline
Lugnutz  Offline
Canada
Nice job Mike...........exactly what I would have done but would have also converted to a 4x4. I think you'll be pleased with the rig once you get it all together.
Re: Crew Cab Oil Burner [Re: Lugnutz] #831140
12/25/10 11:04 AM
12/25/10 11:04 AM
southeast, mich
MachoMan Offline
MachoMan  Offline
southeast, mich
love it!
man, i need a garage.
Please register your Dodge truck here 1972-1980 Dodge truck registry
Re: Crew Cab Oil Burner [Re: MachoMan] #831141
12/28/10 09:09 PM
12/28/10 09:09 PM
Sparks, Nevada
Sparks, Nevada
The thought of selling it has crossed my mind again (I'm pretty indecisive). I have other projects that need attention (77' D-150) and the wife really doesn't like the truck. So what do you think its worth. I've been toying with posting it for sale again but there are few comparable trucks for sale. I haven't officially said it's for sale because I don't know if its worth getting rid of yet. I've ordered the radiator and hoses but it still needs a fan assembly and shroud, a/c condenser, and decent tires. It still needs a few things finished. What do you think its worth? This is a link to a couple photos of the truck last week and a bunch from before I began the conversion. I'll have a few more with the CTD installed soon.
http://s864.photobucket.com/albums/ab206/superbeemike/Pete/?albumview=slideshow
Let me know what you think. Is it worth keeping or getting my money out of it? Should I finish it first, or sell it as is?
Mike
1969 Superbee 440-6
2000 Jeep TJ
2019 Ram 2500 CTD
Re: Crew Cab Oil Burner [Re: MoparMike23] #831142
12/28/10 10:27 PM
12/28/10 10:27 PM
Lenox Iowa
MMiller Offline
MMiller  Offline
Lenox Iowa
FWIW I bought an 85 crew cab with cummins conversion, decent paint, auto for $5500. I saw one on 1stgen.org for the same amount.
I am going to convert mine to a manual(hopefully a 6 speed) so it tows better. I would encourage you not to sell it, unless you don't tow very often. I needed a truck to pull my gooseneck with and haul my family. A standard cab won't cut it with a wife and three kids.
Michael
93 W250 CTD getrag, Bosch 185 injectors, AFE air filter. Trailer puller, daily driver,
90 W250 CTD 727 with smokin 5" stacks. Off road truck
75 Dodge W200 440 4spd 4x4 locked front and rear, twin disc clutch, E85. Pulling truck
Re: Crew Cab Oil Burner [Re: MMiller] #831143
12/29/10 12:27 PM
12/29/10 12:27 PM
Sparks, Nevada
Sparks, Nevada
Michael
Thats a bit of my problem. I have three kids. I really only tow something heavy a few times a year (the Super Bee to shows) and thats nothing the D-150 can't handle. My towing worries would disappear if I would man up and drive that car more instead of pulling it everywhere.
1969 Superbee 440-6
2000 Jeep TJ
2019 Ram 2500 CTD
Re: Crew Cab Oil Burner [Re: MoparMike23] #831144
12/29/10 06:08 PM
12/29/10 06:08 PM
Canada
Lugnutz Offline
Lugnutz  Offline
Canada
Mike, there is an exact truck like what you have finished in Colorado, same color, running and driving and the guy couldn't get 5k.
At one time these trucks(Crew Cab Conversions) were fetching some good coin. Don't know if the market is still there.
Good luck
Re: Crew Cab Oil Burner [Re: Lugnutz] #831145
12/29/10 08:11 PM
12/29/10 08:11 PM
Byron, NY
W.I.N. Racing Online content
W.I.N. Racing  Online Content
Byron, NY
Good luck
since 03 when the crew cab was re-introduced, the first gen Crew prices have been droping.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Crew Cab Oil Burner [Re: W.I.N. Racing] #831146
12/30/10 12:21 PM
12/30/10 12:21 PM
Sparks, Nevada
Sparks, Nevada
That makes a lot of sense although the 03-09 quad never seemed very big.
I'd have a hard time replacing the truck without jumping into a payment again. Looks like I'll keep it around and finish it. I'll probably fall in love with it once I get it registered and drive it around.
1969 Superbee 440-6
2000 Jeep TJ
2019 Ram 2500 CTD
Re: Crew Cab Oil Burner [Re: MoparMike23] #831147
12/30/10 04:40 PM
12/30/10 04:40 PM
Northeast, Alpine, NY
9
9 Sec Phill Offline
On a road near you
9 Sec Phill  Offline
On a road near you
9
Mike, I went to a local pick and pull and found a 92 CTD. motor and trans were MIA but in the back was some parts you could use. Heres a pic. Let me know if I can help...Phill
Re: Crew Cab Oil Burner [Re: MoparMike23] #831148
12/30/10 06:46 PM
12/30/10 06:46 PM
Byron, NY
Byron, NY
leg room is about the same 1st Gen to 3rd Gen crews.
'60 Willys CJ5
Re: Crew Cab Oil Burner [Re: 9 Sec Phill] #831149
12/30/10 06:49 PM
12/30/10 06:49 PM
Sparks, Nevada
Sparks, Nevada
Sure could use that shroud if its from that truck. Let me know how much. Might even want the cooler. Thanks
1969 Superbee 440-6
2000 Jeep TJ
2019 Ram 2500 CTD
Page 2 of 4 1 2 3 4
