Overcharging issue - Voltage regulator to blame?
#830841
10/16/10 12:44 AM
10/16/10 12:44 AM
Posts: 4,481 Mesa, AZ
Pat_Whalen
super gas
super gas
Mesa, AZ
Haven't started delving into all of the possible problems, but I'd like some feedback on things to look into. Truck starts up and, during an idle, will be feeding 12.5-13 volts to the battery. Problem begins when I'm driving it around. Voltmeter (tested and good against a multimeter) climbs exponentially in relation to the RPMs I'm currently at. There seems to be no regulation on how much voltage the alternator is sending out. Cruising at 2000RPM, the voltmeter reads 17 volts and might actually be pegged. Haven't ran a voltmeter simultaneous to find out actual value. Just know that it's too high. Does this sound like a bad voltage regulator? I haven't tried another one and I can't verify that this one is good. I do know that I've got a good ground at the regulator. Thanks in advance.
Re: Overcharging issue - Voltage regulator to blame?
[Re: Pat_Whalen]
#830842
10/16/10 12:50 AM
10/16/10 12:50 AM
Posts: 905 SD
zrxkawboy
SD
Most any parts store can test your VR.
It's Swifty! Swifty, you toad sucker!
[Re: Pat_Whalen]
#830844
10/16/10 01:17 AM
10/16/10 01:17 AM
RapidRobert
Yes. I just had one ('70 up flat VR) suddenly start pegging as soon as I gave it throttle. Checked it's ground w a jumper wire w alligator clips/no change. R&R'd it & back to good. EDIT I would deal w it ASAP before it burns some wiring/connections & I'd unplug it rather than let it overcharge 'till you get it
[Re: RapidRobert]
#830845
10/16/10 03:38 AM
10/16/10 03:38 AM
Pat_Whalen
super gas
super gas
Mesa, AZ
So unplugging the VR will result in a no-charge state? Or just the standard 12.5-13V charge?
I'll take your guys word for it and slap a new voltage regulator on there. Like I said, I have no way of knowing that the one on there now is good. Although, I have no way of knowing that the foreign-made one I buy from Checker will be good either....
I'll keep my fingers crossed
[Re: Pat_Whalen]
#830847
10/16/10 10:43 AM
10/16/10 10:43 AM
RapidRobert
Yes & if it does not go to discharge then what 1 wild rt said it is a wiring prob (eyeball the brushes too) rather than the VR. I would pull the plug as that will be akin to leaving your lights on & draining the batt which is far less damaging than the full fielding that is happening right now w it.
