Center section woes
#830086
10/14/10 11:42 PM
10/14/10 11:42 PM
Posts: 2,048 N.E.Ohio
Polarabill
N.E.Ohio
I have a 64 Polara with what I believe is a 70 B body 8 3/4" housing. I've been running a 741 case 3:23 Sure grip center section for a number of years with out problem. I decieded to try a 3:91 gear to see how it runs. I borrowed a 741 cased 3:91 and installed it.I drove it home from my buddy's shop in the rain.The trip was less than 10 miles and it seemed to work fine. A couple of days later when it quit raining I went to go for a test ride and the car wouldn't move.The drive shaft spun but the wheels wouldn't move.I pulled that S/C out an reinstalled the 3:23.Every thing worked fine.Yesterday I purchased a used 741 cased 3:91 and installed it today.Finished it up and went to go for a test drive and once again the drive shaft spins but the car won't move. I used Valvoline 80w90 sure grip gear oil.Am I just one unlucky SOB or am I doing something wrong? I should also add that both 3:91's supposedly worked fine in the cars they came out of. Any ideas before I tear this thing apart again and reinstall the 3:23's?
This would be so much easier if I knew what I was doing...
Re: Center section woes
[Re: DoctorDiff]
#830088
10/15/10 01:01 AM
10/15/10 01:01 AM
Polarabill
N.E.Ohio
I removed the C/S and reinstalled the axles.I had 1.5" inbetween the axles.What is the difference between the 3:23's and the 3:91's that the axles would work in one and not the other?
[Re: Mopar_Country]
#830090
10/15/10 01:18 AM
10/15/10 01:18 AM
Polarabill
N.E.Ohio
Thanks for the info. Tomorrow I'll pull it apart again and check the splines inside the S/C.I guess I'll go back to the 3:23's until I can afford to buy a new center section.Called the guy I bought the 3:91's from and he agreed to refund my money.Stand up guy,don't know if he's a member here or not.I'll ask him when I see him.
[Re: Polarabill]
#830091
10/15/10 11:24 AM
10/15/10 11:24 AM
Polarabill
N.E.Ohio
Well,I think I figured out my problem. I think that the diameter of my axles is smaller than what the two sets of 3:91's use. I don't have a micrometer handy to confirm this,but I'm fairly certain thats the deal. Thanks again to those who replied.
[Re: Polarabill]
#830092
10/15/10 12:18 PM
10/15/10 12:18 PM
Posts: 75,080 U.S.S.A.
JohnRR
U.S.S.A.
What are the chances you found two 3.91 chucks that had different than stock side gears ?
[Re: Polarabill]
#830093
10/15/10 05:34 PM
10/15/10 05:34 PM
Posts: 25,910 Rio Linda, CA
John_Kunkel
Rio Linda, CA
All 8 3/4" axle splines are the same diameter.
