Front Shock washers and bushing questions #830015
10/14/10 10:29 PM
10/14/10 10:29 PM
Shopping @ HoBo Fright
340SIX Offline OP
Doc Flappergas's Evil Twin
340SIX  Offline OP
I have some over the counter replacement type gas filled.
They have this type washers and bushings
Re: Front Shock washers and bushing questions [Re: 340SIX] #830016
10/14/10 10:31 PM
10/14/10 10:31 PM
Georgetown Ontario Canada
anlauto Offline
anlauto  Offline
That's nice
CHECK OUT MY NEW WEB SITE !
Re: Front Shock washers and bushing questions [Re: 340SIX] #830017
10/14/10 10:32 PM
10/14/10 10:32 PM
340SIX Offline OP
340SIX  Offline OP
The bushings and washers are very small in Diamiter compaired to the correct ones I bought
Re: Front Shock washers and bushing questions [Re: 340SIX] #830018
10/14/10 10:36 PM
10/14/10 10:36 PM
340SIX Offline OP
340SIX  Offline OP
I do not see away to use the new washers with the old bushings.
The picture I found on a members site shows the correct bushing to be very long.
I am guessing I would need a new lower correct looking washer as well,and just one whole long bushing is used instead of 2 halfs is this the case?
Re: Front Shock washers and bushing questions [Re: anlauto] #830019
10/14/10 11:03 PM
10/14/10 11:03 PM
anlauto Offline
anlauto  Offline
I would use the correct washers on both sides of the bushing. There is a washer/bushing kit that you can buy.
You could try using the small washer on the bottom, I don't really see a lot of problems with that idea...
Paint the shocks semi black and be done !
Re: Front Shock washers and bushing questions [Re: anlauto] #830020
10/14/10 11:28 PM
10/14/10 11:28 PM
340SIX Offline OP
340SIX  Offline OP
Alan does the orginal system use one bushing per side like pictured?
Re: Front Shock washers and bushing questions [Re: 340SIX] #830021
10/15/10 12:56 AM
10/15/10 12:56 AM
At a gas station near you
badblack68 Offline
badblack68  Offline
One bushing and two washers per side. We have both in stock.
Nobody gets in to see the wizard!
Ain`t no way!
Ain`t no how!
Re: Front Shock washers and bushing questions [Re: anlauto] #830022
10/15/10 08:15 AM
10/15/10 08:15 AM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
Kevin,
I'll explain it better here.
There is only one bushing per side.
You remove the inner sleeve, slide the bushing into the chassis, re-install the sleeve then put the shock in with one each washer on top and bottom. Tighten the nut down until it squashes the bushing,, the sleeve stops it from being over tightened
