motor mount question #829968
10/14/10 08:58 PM
10/14/10 08:58 PM
northeast pa
3wracing Offline OP
3wracing  Offline OP
northeast pa
taking the poly motor out of my 65 coronet and installing a big block , can anyone tell me what motor mounts to use ? and what driveshaft will work.
Re: motor mount question [Re: 3wracing] #829969
10/14/10 10:15 PM
10/14/10 10:15 PM
Berlin, WI
safetymike1977 Offline
Berlin, WI
I have used big blocks on some earlier cars that came with polys. You should be able to use the can style mounts from a 58-6? big block. If yours has can style mounts, you can actually use them with some modifications..
Re: motor mount question [Re: safetymike1977] #829970
10/15/10 08:21 AM
10/15/10 08:21 AM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
rubber insulators are the same for any V8 wedge 1963-1964-1965,in a B-body, all you need are the correct steel engine mounting brackets, here is a picture, they are sold in the Moparts.com B-body parts for sale section....
Re: motor mount question [Re: Joesixpack] #829971
10/15/10 08:24 AM
10/15/10 08:24 AM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
driveshaft depends on what transmission you use....4 speed? 727? slip yolk?bolt on ? you just need to get the engine,trans&rear axle installed and get the correct yolk,then measure center to center of the u-joints to get correct length.
