Upper radiator hose 1970 b body 440 #829629
10/14/10 02:09 PM
10/14/10 02:09 PM
kentucky
roadrunner7020 Offline OP
kentucky
Can anyone post the part number from your local auto store for the upper radiator on a 1970 roadrunner 440 4 bl with 26inch radiator I don't need the number stamped on like factory just a replacement and all the ones I get from parts stores are wrong. Looking for molded not flex hose thanks
Re: Upper radiator hose 1970 b body 440 [Re: roadrunner7020] #829630
10/14/10 03:39 PM
10/14/10 03:39 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
Gates - 20630
Goodyear - 60664
these are 2 different shapes but the gates hose resembles the OE 2963257 hose more closely
where as the goodyear hose resembles the OE 2806186 hose
I have them both on hand if you can't find one locally
Re: Upper radiator hose 1970 b body 440 [Re: gtx6970] #829631
10/14/10 04:02 PM
10/14/10 04:02 PM
kentucky
kentucky
I purchased the 20630 from rockauto and it got here today it's too short is the Goodyear one any longer? The new reproduction one looks perfect but at 75-100 dollars a hose on a non numbers car that's crazy
Re: Upper radiator hose 1970 b body 440 [Re: roadrunner7020] #829632
10/14/10 04:08 PM
10/14/10 04:08 PM
It's a dry heat
It's a dry heat
Never had one to short before, is this a stock radiator?
Re: Upper radiator hose 1970 b body 440 [Re: gtx6970] #829633
10/14/10 05:02 PM
10/14/10 05:02 PM
kentucky
kentucky
Bolt in replacement all aluminum but I bought a hose a while back for the stock rad and it works resembles the hose the Goodyear replaces and Mopar reproduces I haven't put the gates on but in comparison it looks short I called my auto store with the good year and they cross referenced it with a different gates crossing my fingers
Re: Upper radiator hose 1970 b body 440 [Re: gtx6970] #829634
10/14/10 07:32 PM
10/14/10 07:32 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Bill is the Goodyear hose for A/C?
Re: Upper radiator hose 1970 b body 440 [Re: roadrunner7020] #829635
10/14/10 07:52 PM
10/14/10 07:52 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
If it don't fit get a B-body Hemi hose from Bill.It's long enough to fit any application.
Re: Upper radiator hose 1970 b body 440 [Re: A12] #829636
10/14/10 09:08 PM
10/14/10 09:08 PM
It's a dry heat
It's a dry heat
Both are for max cooling ( A/C included ) Just shaped differently per each manufacturer for the same application
