need under dash vacuum diagram 71 plymouth w/ac #828008
10/12/10 08:20 AM
10/12/10 08:20 AM
Tampa FL
hemibeep Offline OP
hemibeep  Offline OP
Tampa FL
I am working on the vacuum lines that were melted underdash on my 71 runner'. can anyone post the diagram?
thanks
Re: need under dash vacuum diagram 71 plymouth w/ac [Re: hemibeep] #828009
10/12/10 05:37 PM
10/12/10 05:37 PM
Chicagoland
JohnnySivilian Offline
Chicagoland
How different is it from a satellite? Ive got a 73 plymouth manual that I'm trying to use to fix my challenger and it shows satellite hvac.
Re: need under dash vacuum diagram 71 plymouth w/ac [Re: JohnnySivilian] #828010
10/12/10 06:45 PM
10/12/10 06:45 PM
Tampa FL
hemibeep Offline OP
hemibeep  Offline OP
Tampa FL
should be similar, any help would be great
thanks
Re: need under dash vacuum diagram 71 plymouth w/ac [Re: hemibeep] #828011
10/12/10 10:27 PM
10/12/10 10:27 PM
Chicagoland
Chicagoland
here's some pics i took with my phone. I just moved and haven't hooked up my scanner yet. they look ok to me. hope this helps you in some way.
Re: need under dash vacuum diagram 71 plymouth w/ac [Re: JohnnySivilian] #828012
10/12/10 10:28 PM
10/12/10 10:28 PM
Chicagoland
Chicagoland
another.
Re: need under dash vacuum diagram 71 plymouth w/ac [Re: JohnnySivilian] #828013
10/12/10 10:29 PM
10/12/10 10:29 PM
Chicagoland
Chicagoland
another
Re: need under dash vacuum diagram 71 plymouth w/ac [Re: JohnnySivilian] #828014
10/12/10 10:32 PM
10/12/10 10:32 PM
Chicagoland
Chicagoland
this is the wiring for the hvac system if you need it
Re: need under dash vacuum diagram 71 plymouth w/ac [Re: JohnnySivilian] #828015
10/12/10 10:35 PM
10/12/10 10:35 PM
Chicagoland
Chicagoland
this is the bottom part of the page. the solid line is the active vacuum circuit.
Re: need under dash vacuum diagram 71 plymouth w/ac [Re: JohnnySivilian] #828016
10/12/10 10:37 PM
10/12/10 10:37 PM
Chicagoland
Chicagoland
here's the last one
