3D0727 Gear Vendors Under/Overdrive GOOD? BAD? #827633
10/11/10 09:37 PM
10/11/10 09:37 PM
ca, slo.
P
paulyvault Offline OP
P
ca, slo.
has anyone had experience with a 3D0727 Gear Vendors Under/Overdrive for Chrysler A727. ?? what is A727 is it for an "A" Body? any info on this item would be great. thanks
paul
Re: 3D0727 Gear Vendors Under/Overdrive GOOD? BAD? *DELETED* [Re: paulyvault] #827634
10/11/10 09:45 PM
10/11/10 09:45 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Post deleted by bboogieart
Re: 3D0727 Gear Vendors Under/Overdrive GOOD? BAD? [Re: bboogieart] #827635
10/11/10 09:50 PM
10/11/10 09:50 PM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
A727 does not designate small block or big block; it is simply Chrysler's designation for the trans.
It's Swifty! Swifty, you toad sucker!
Re: 3D0727 Gear Vendors Under/Overdrive GOOD? BAD? [Re: zrxkawboy] #827636
10/11/10 10:25 PM
10/11/10 10:25 PM
Northern New Jersey
EV2AAR Offline
EV2AAR  Offline
Northern New Jersey
I put one in a 73 Dart 2 years ago , I driven about 4 thousand miles with no issues. As far as the install.....take out the seat and carpet , you will have to cut a small piece out of the tunnel to make it wider. Get a new driveshaft, well worth it , I put the control box under the drivers side kick panel.
Just put about 500 miles on it the past weekend
70mph 2500 RPM 3.55 gears.
On of the two best investments I did to the car.
Re: 3D0727 Gear Vendors Under/Overdrive GOOD? BAD? [Re: EV2AAR] #827637
10/11/10 11:46 PM
10/11/10 11:46 PM
Bucks County, PA
500Stroker Offline
500Stroker  Offline
Bucks County, PA
Put mine in my Challenger over 5 years ago. Over 40,000 trouble free miles. Hands down the best upgrade I did to the car. No cutting for me. Just a little air hammer on the passenger side tunnel.
The GV bolts to the rear of the transmission with a new tail housing.
Part No.: 3D0727
Application: TF 727 3-Speed Auto Transmission
Description: Replaces 18 1/2" tail housing.
Comments: Chrysler vans, pickups and mini-motorhomes without driveline park brake.
Price Code B
Re: 3D0727 Gear Vendors Under/Overdrive GOOD? BAD? [Re: 500Stroker] #827638
10/12/10 12:48 AM
10/12/10 12:48 AM
hudson valley n.y.
GEORGE68HEMIRR Offline
super street
super street
hudson valley n.y.
money well spent......installed in my car in the spring......430 gears and now i have both worlds.......street/strip
Re: 3D0727 Gear Vendors Under/Overdrive GOOD? BAD? [Re: GEORGE68HEMIRR] #827639
10/12/10 01:26 AM
10/12/10 01:26 AM
ca, slo.
P
P
ca, slo.
did you use the 3D0727 or did you use the 3D0731? if you could let me know at paulyvault@hotmail.com that would be much apreciated. thanks
Re: 3D0727 Gear Vendors Under/Overdrive GOOD? BAD? [Re: EV2AAR] #827640
10/12/10 01:28 AM
10/12/10 01:28 AM
ca, slo.
P
P
ca, slo.
Re: 3D0727 Gear Vendors Under/Overdrive GOOD? BAD? [Re: paulyvault] #827641
10/12/10 03:07 AM
10/12/10 03:07 AM
PA
Moparzrule Offline
Moparzrule  Offline
PA
I don't know where your getting those part numbers from but you want:
Part #3DFS727A
Automatic 3-Speed 727 18" Tailhousing.
Replaces 18 1/2" tailhousing.
60's and 70's muscle cars and street rods.
http://www.gearvendors.com/aghr3s.html
Are you sure you even have a 727 in your car?
My
Own
Personal
Adrenaline
Rush
