Re: Who's running SB turbo setups
[Re: dizuster]
#827606
11/07/10 01:26 AM
11/07/10 01:26 AM
Posts: 1,090 north cakalaky
instigator
north cakalaky
Can't make 850..hell so, I made 700rwhp at 15psi on twin 61mm turbos...800rwhp at 20psi and 900 at 25 psi....all on the small 61's All on edelbrocks...408ci and 245/.565 lift FT cam Tomorrow ill be cranking up the new mule with my 2 year old Shady Dell 230cc -2's..259/255 .640 lift FT cam with Smith Machine lifters(ceramic faced) (sorry Ryan to let them sit so long), twin 75mm turbos...I am so siked! Heres a pic from yesterday morn.... ![](http://i249.photobucket.com/albums/gg215/turbocuda/IMG_20101105_162955.jpg) Pretty much mostly buttoned up now...just a few minor things to finish tomorrow.
65 Barracuda All aluminum Indy HEMI with some boost! COMING TO A TRACK NEAR YOU!
[Re: instigator]
#827607
11/07/10 11:14 AM
11/07/10 11:14 AM
Posts: 1,044 Victoria, Australia
Ian
Victoria, Australia
well done that is mean combo , your old combo was tuff but the new one is crazzy tuff lol good luck ![](/ubbthreads/images/graemlins/beer.gif)
[Re: TheOtherDodge]
#827609
11/07/10 10:40 PM
11/07/10 10:40 PM
Ian
Victoria, Australia
Are some people misunderstanding when I/others are saying the ability to make the power is not a problem, it is the ability for the stock block to handle it...???
i run a std 360 block it run 9.98@134 @3550 lbs with nos ,and my mates car runs 8.63@159 mph @3400 lbs with a single turbo these are 70-72 blocks i was told there stronger than the later ones ,mine is grout filled mates is the same but has splade caps ,i am not saying your wrong some people have made good power with them and some have not and thanks for the detailed build . ![](/ubbthreads/images/graemlins/beer.gif)
[Re: TheOtherDodge]
#827612
11/09/10 08:49 PM
11/09/10 08:49 PM
Posts: 142 Maryland
Sick 660r
Maryland
the main webbing in the LA's is thicker then the magnums.
2000 dakota
418 magnum
paxton novi 2k
T56
[Re: rtspeeddemon]
#827615
11/12/10 01:09 PM
11/12/10 01:09 PM
Posts: 1,969 Chandler, AZ
Duner
Chandler, AZ
I run a turbo set-up on my 360 ,magnum block stroked to a 408.
I'm glad my Magnum block doesn't surf the internet. I don't want it saying "me too".
Oh yeah. Turbo'd SB here too.
[Re: TheOtherDodge]
#827616
11/12/10 04:57 PM
11/12/10 04:57 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
"Magnum blocks are not as strong as the LA blocks."
Why? I have been told the other way around, but no one can tell me why.
I still say with that cam, head combo 800 is not going to happen. 750 tops. Oh and yes I talked to my buddy w/ the turbo 392 and he's around 1000.
[Re: Mr.Yuck]
#827617
11/13/10 02:30 PM
11/13/10 02:30 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
That cam is plenty big... the cam of choice for the ford guys seems to be the old F-303 226/226@.050" .512" lift, hydraulic roller. Like I said. Search the internet. You don't need to find a 410" w2 motor to compare too. Pretend the ford and chevy badges on the motor don't matter, and just think of it as an engine. Compare turbo's, cams, head flow, etc... Before you say "it can't, or it won't" look around a little. There are LOTS of them... This has an even smaller turbo, same cam and heads flows 310cfm @.700" (hmmm... sound like a W2?) Tell me this doesn't make 850fwhp ![](/ubbthreads/images/graemlins/rolleyes.gif) 351w .030 - DSS Pro XR max quench dish 30cc dish, 4340 h- beam rods, STOCK CRANK & no main girdle, no block filler!! F4TE block AFR 205's - $30 head gaskets - never had problem!! AMF B-451 cam (232*/240* 299*/307* - .576"/.576") - stock 200,000 mile lifters Victor Jr. Intake 750 CSU - Kevin did a great job on the carb it looks Bling-bling S400 -75mm no race cover with 1.32ar - Thanks to www.turbodaves.com - Highly recommend him for any turbo purchase. 60mm wastegate - ebay wastegate 50mm BOV - of them (ebay BOV) Powerglide with Edge - Pro series convertor Magnafuel Pro Star 500 13202 Regulator Dynojet WideBand Commanders MSD Boost Launch Control MSD 7531 60' - 1.329 330 - 3.576 1/8 - 5.458 mph - 128.26 Here is the link... http://www.theturboforums.com/smf/index.php?topic=84871.msg890590#msg890590
[Re: dizuster]
#827618
11/14/10 12:56 PM
11/14/10 12:56 PM
Posts: 4,953 Houston, Texas
TheOtherDodge
Houston, Texas
![](/ubbthreads/images/graemlins/iagree.gif) When I first started talking to my turbo builder and told him my combo (392, ported Eddy heads that flow around 280, .228/.236, .544, 114 lsa hydraulic roller, 9.3:1 compression) he asked how much power I wanted to make using a 76 mm turbo, and I said "600 rwhp which is about 710 crank hp" and his comment was "that's it???".....
[Re: Craig J]
#2672359
07/01/19 09:24 AM
07/01/19 09:24 AM
Posts: 8,038 Tulsa OK
Bad340fish
Tulsa OK
I have been heavily considering turbo stuff for my small block as well. Currently it is a 416" R1 block with ported W2 heads and runs 10.50s@3550lbs. I would love to tame the big solid roller down a little to be easier on parts and throw some boost at it. I already have EFI and lots of fuel system....I just need time and money haha. What I really want to do is take some of the racecar out of my street car but make it faster at the same time. Easy right? ![realcrazy realcrazy](/ubbthreads/images/graemlins/custom/realcrazy.gif)
68 Barracuda Formula S 340
