Full Undercoating #827499
10/11/10 08:07 PM
10/11/10 08:07 PM
ohio
m300b Offline OP
m300b  Offline OP
ohio
66' Belvedere convertible. On a "FULL" undercoat does the whole floor pan get coated? Where do I stop in the engine compartment? Want a low maintenance car. Bottom was blasted and sprayed with 4 coats of Zero-Rust. Thanks
Re: Full Undercoating [Re: m300b] #827500
10/11/10 09:05 PM
10/11/10 09:05 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
almost the entire floor was undercoated , under the gas tank was not since the gas tank and all the lines and such were installed before undercoating. As far as where to stop up front, right at the seam where the firewall meets the floor pan.
Re: Full Undercoating [Re: JohnRR] #827501
10/11/10 10:11 PM
10/11/10 10:11 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
How about the bottom of the front frame rails and how much gets on the K frame?
Re: Full Undercoating [Re: RoadRunnerJD] #827502
10/12/10 01:39 PM
10/12/10 01:39 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
The K fram would not be in the car at undercoating
Re: Full Undercoating [Re: RoadRunnerJD] #827503
10/12/10 01:53 PM
10/12/10 01:53 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Not really sure, do you want a factory look ?
The cars were sprayed by a human standing in a pit, no 2 are the same, I would just run straight across from the firewall seam back.
Re: Full Undercoating [Re: JohnRR] #827504
10/12/10 03:18 PM
10/12/10 03:18 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
How about the before restoration pictures of this particular car??
Re: Full Undercoating [Re: JohnRR] #827505
10/12/10 05:05 PM
10/12/10 05:05 PM
Ball Ground GA
TrueTripleX Offline
TrueTripleX  Offline
Ball Ground GA
Good to know JohnRR. Were the brake lines and body plugs in at this time too?
Re: Full Undercoating [Re: TrueTripleX] #827506
10/12/10 05:18 PM
10/12/10 05:18 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Yes, all that stuff was installed prior to undercoating. I assume the undercoating was sprayed very shortly before the "body drop" phase of assembly.
Re: Full Undercoating [Re: burdar] #827507
10/12/10 06:54 PM
10/12/10 06:54 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
resto rick has an assembly order on his web site that shows about 48 step (things installed) before undercoating
