XV lower rad support #827177
10/11/10 01:50 AM
10/11/10 01:50 AM
AndyF Offline OP
AndyF  Offline OP
Had the front bumper off the red Valiant today so I shot a picture of the XV rad support. Very nice product. If you have the ability to weld and to do some minor fabrication then this is a good modification to put on the list.
Re: XV lower rad support [Re: AndyF] #827178
10/11/10 01:51 AM
10/11/10 01:51 AM
AndyF Offline OP
AndyF  Offline OP
Here is a closer view of the XV support.
Re: XV lower rad support [Re: AndyF] #827179
10/11/10 04:44 AM
10/11/10 04:44 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Andy, I've heard someone "say" you could run an XV radiator brace and still run the factory brace. Don't know how true that is. Or what body style that was (I think E-body).
Do you think you could have installed that XV with the factory brace still in it??
Re: XV lower rad support [Re: AndyF] #827180
10/11/10 07:38 AM
10/11/10 07:38 AM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
Is the K frame welded and the steering boxed mount boxed in? Inquiring minds would like to know
Re: XV lower rad support [Re: ThermoQuad] #827181
10/11/10 09:20 AM
10/11/10 09:20 AM
Sacramento, Ca
Darius Offline
Darius  Offline
Sacramento, Ca
I left mine in
Driving modern convenience in classic beauty
Re: XV lower rad support [Re: Darius] #827182
10/11/10 09:22 AM
10/11/10 09:22 AM
the house on the left.
cogen80 Offline
cogen80  Offline
I left mine in
hows the rad fit now?
Re: XV lower rad support [Re: Darius] #827183
10/11/10 09:23 AM
10/11/10 09:23 AM
Sacramento, Ca
Darius Offline
Darius  Offline
Sacramento, Ca
In fact, I welded the existing lower supprort to the XV piece
Re: XV lower rad support [Re: cogen80] #827184
10/11/10 09:28 AM
10/11/10 09:28 AM
Sacramento, Ca
Darius Offline
Darius  Offline
Sacramento, Ca
I left mine in
Haven't put one back yet. My plan is to start with the radiator from the wrecked 07 Charger, which will fit with a TON of room left. I don't see where it would impact the stock radiator.
Re: XV lower rad support [Re: Darius] #827185
10/11/10 04:22 PM
10/11/10 04:22 PM
NotRussia
2
2fast4yourBrain Offline
Whack top Dodger
Whack top Dodger
2
NotRussia
YOu don't mind not being able to get it welded on all four sides on each end?
Pretty sure you have to run a cross-flow radiator unless you weld in the supplied extensions.
Mine:
Re: XV lower rad support [Re: ThermoQuad] #827186
10/12/10 12:28 AM
10/12/10 12:28 AM
auto-xr Offline
auto-xr  Offline
Tom Q- Yes, K frame has been completely seam welded and steering box mounts braced.
68 Valiant- was auto-x now track day car
