Re: Lifter Not Spinning
[Re: SILVER67]
#826330
10/10/10 04:29 PM
10/10/10 04:29 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
If your lifters are .904 then you only have .003 clearance, that sounds pretty close to where it should be sometimes you can scuff the bottom of the lifters with scotch brite to get them rotateing, since they are solids you could also hit the bottom of them with a sandblaster to give them some grip. Remember they only really rotate over the lobe, not on the base circle. How are youchecking for ratation?
[Re: HotRodDave]
#826332
10/10/10 05:06 PM
10/10/10 05:06 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
if they are not spinning and have enough clearance do others spin when in that lifter bore? have you tried swapping them around ? Why is it not spinning due to the lifter or where it's placed is what you need to know. A sign of a lifter going south is the loss of the center of the crown. Are they used ?
then my dumb question are they all cleaned and oiled ? what oil is on them now ? Some oil when cold will be enough to throw you a curve ball and stop the lifter from turning
home of the Sox and Martin Hemi Duster
[Re: SILVER67]
#826334
10/10/10 07:14 PM
10/10/10 07:14 PM
HEMIFRED
SOUTH JERSEY
So is it only a few lifters or the lifter bores that are source of problem ?
I can't figure exactly from your reply
[Re: HEMIFRED]
#826341
10/11/10 01:12 AM
10/11/10 01:12 AM
HotRodDave
Kalispell Mt.
If the burnishing ball don't fix it then it is also possible the lifter bore is not straight up and down over the lobe. This causes there to not be one side of the lobe touching the lifter forceing it to rotate, the only way to fix that is to bush the lifter bore. Even running a roller in a bore that bad could cause un even loading of the lifter and make it wear out too fast.
[Re: HEMIFRED]
#826342
10/11/10 01:54 AM
10/11/10 01:54 AM
HEMIFRED
SOUTH JERSEY
Mike have you ran the motor before and were there any problems with the lifters
