Driveshaft loop for Challenger ? #826006
10/10/10 07:18 AM
10/10/10 07:18 AM
Richmond Va, KeislerTKO 60...
V
VanishPt Offline OP
VanishPt  Offline OP
V
70 Challenger with X pipe and Tremec Tko Transmission.
What are you guys using for a drive shaft loop?
If I were to try to fab one up, what size steel should i use?
Re: Driveshaft loop for Challenger ? [Re: VanishPt] #826007
10/10/10 07:44 AM
10/10/10 07:44 AM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
I like this,,,i have one on my Charger,,no issues with clearance,,,not sure if it would be a issue on your car,,,
You can go to the sponsers page on this site and see it listed,,, i think it is with US Tool,
hope this helps.
Doug
Re: Driveshaft loop for Challenger ? [Re: 69CHARGERMD] #826008
10/10/10 10:26 AM
10/10/10 10:26 AM
IN
ahy Offline
ahy  Offline
IN
I used a Lakewood universal loop (Mancini) bolted through the floor on a '70 Challenger with 3" X pipe. Pro's are it is fairly inexpensive and stout. Cons are I had to re-bend and re-drill the hoops to get the right fit.
If I do it again, I would get the fitted loop from Auto Rust Technicians. More expensive but doesn't require hours of bending, cutting and drilling.
Re: Driveshaft loop for Challenger ? [Re: 69CHARGERMD] #826009
10/10/10 10:31 AM
10/10/10 10:31 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I use the same one, although my Stage VI's raised exhaust ports had an impact on the clearance and I had to get part of the bolt-together assembly for the loop welded to eliminate the bolts and provide additional clearance. I have no idea what the aftermarket trans' impact on fitment might be.
Re: Driveshaft loop for Challenger ? [Re: VanishPt] #826010
10/10/10 10:36 AM
10/10/10 10:36 AM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
The US CAR TOOL one(which is a nice piece), will not work with the Tremec and the crossmember that you are using(I am assuming Keisler). I made one for a 63 Dodge that was pretty good and worked well with the X pipe, but the pics are at the shop computer. I will try to remember to post it later.
MB
Re: Driveshaft loop for Challenger ? [Re: 69CHARGERMD] #826011
10/10/10 12:16 PM
10/10/10 12:16 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
hope this helps.
Doug
+1
Re: Driveshaft loop for Challenger ? [Re: BradH] #826012
10/10/10 04:39 PM
10/10/10 04:39 PM
IN
ahy Offline
ahy  Offline
IN
I use the same one, although my Stage VI' raised exhaust ports changed had an impact on the clearance and I had to get part of the bolt-together assembly for the loop welded to eliminate the bolts and provide additional clearance. I have no idea what the aftermarket trans' impact on fitment might be.
I used the universal bolt to the floor type with a Keisler 5 speed. One advantage is flexibility... you can adjust where you bolt it through the floor as well as loop position... it just seems to take a fair amount of cutting, drilling bending and welding to get the loop in the right spot.
Re: Driveshaft loop for Challenger ? [Re: ahy] #826013
10/10/10 05:52 PM
10/10/10 05:52 PM
Walla Walla, WA
Hemi_Jack Offline
Hemi_Jack  Offline
Walla Walla, WA
I don't have a tremec or the X-pipe but this is the driveshaft loop that I went with.
http://www.metcomotorsports.com/proddetail.asp?prod=MDL1900
Re: Driveshaft loop for Challenger ? [Re: Hemi_Jack] #826014
10/10/10 06:48 PM
10/10/10 06:48 PM
V
VanishPt Offline OP
VanishPt  Offline OP
V
Thanks for the info guys. That last one looks interesting.
