Page 4 of 6 1 2 3 4 5 6
Re: Project "69 Twin TurboCharger" [Re: Fury Fan] #825888
02/14/11 07:00 PM
02/14/11 07:00 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
By what I see on his and have experience with mine the plugs will be easy. Make sure the headers have cooled and go up from underneath the car.
Installing a shock absorber will be a PITA. If the heat kills the rubber shock bushing the shaft will beat a hole in the primary directly above it.
- Stu Harmon
Re: Project "69 Twin TurboCharger" [Re: feets] #825889
02/15/11 04:16 AM
02/15/11 04:16 AM
Reno, NV
W
Wilde Racing Offline OP
W
Reno, NV
thanks for the tips...
Feets, You got me very worried about the shock bushing. I went out and measured. I have over an inch of clearance from the hole face. I plan on making a heat shield but you got me wondering..... thanks..... lol
Re: Project "69 Twin TurboCharger" [Re: Wilde Racing] #825890
02/21/11 08:24 PM
02/21/11 08:24 PM
Reno, NV
W
W
Reno, NV
Well it's time to start welding
I also raised number six primary to gain "air" room for the poor shock bushing..
Re: Project "69 Twin TurboCharger" [Re: Wilde Racing] #825891
02/22/11 06:49 PM
02/22/11 06:49 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Those are awesome headers. The work that goes into them makes me really like my logs.
- Stu Harmon
Re: Project "69 Twin TurboCharger" [Re: feets] #825892
02/23/11 12:42 PM
02/23/11 12:42 PM
Reno, NV
W
W
Reno, NV
Thanks, The work make me rethink my plans....
Does the shock bushing gap look a bit better to you? I'm still kinda worried (thanks to you) about the side of the bushing nearest the cab.. I hope a heat shield and a urethane bushing will work.....
Re: Project "69 Twin TurboCharger" [Re: Wilde Racing] #825893
02/23/11 10:28 PM
02/23/11 10:28 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Nice work on the headers! Man I want to put a hair dryer or 2 on my Dart and lookin at the very limited build ups there are on Mopars twins seem to be the better fit in the engine compartment. Other than the expense of have to buy 2 of everything!
Mopar to the bone!!!
Re: Project "69 Twin TurboCharger" [Re: 72Swinger] #825894
02/24/11 11:44 AM
02/24/11 11:44 AM
Reno, NV
W
W
Reno, NV
Your right, two are kinda easier on fittment, but not when it comes to things like intercoolers and charge pipe routing.....
Re: Project "69 Twin TurboCharger" [Re: Wilde Racing] #825895
02/24/11 04:25 PM
02/24/11 04:25 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Wow those look good. you should send them to china and have a 100 sets made. I'm sure you sell every set.
Coming soon!!!!
Re: Project "69 Twin TurboCharger" [Re: Mr.Yuck] #825896
02/24/11 11:55 PM
02/24/11 11:55 PM
Reno, NV
W
W
Reno, NV
Thanks.. The problem with that idea is that if I sent them to china the welds will look like I welded them....
Re: Project "69 Twin TurboCharger" [Re: Wilde Racing] #825897
02/25/11 10:57 AM
02/25/11 10:57 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
What do you want for a set? I know I just dropped this motor but you have to plan ahead ya kinow. Very impressive. Did you tack right thru the hose clamp?
Coming soon!!!!
Re: Project "69 Twin TurboCharger" [Re: Mr.Yuck] #825898
02/25/11 12:42 PM
02/25/11 12:42 PM
Reno, NV
W
W
Reno, NV
No, I took the clamps off one by one as I tacked. As far as price.... yikes, I have no idea a lot??? And with all the room clearance issues, I dont think I could mass produce, each set would have to be custom made for each car....
Re: Project "69 Twin TurboCharger" [Re: Wilde Racing] #825899
02/25/11 03:33 PM
02/25/11 03:33 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I'm glad that someone is learing from one of my mistakes. Now if I could only learn from them....
You should be okay with that much air. Will the urethane melt before the rubber breaks up? My rubber bushings never melted. They got cooked and fell off in pieces. A little wrap or light heat shield should do the trick.
It's hard to see the clearance from this angle but the driver's side had no issues at all. The passenger side was so close that when the bushing died the threaded end of the shock beat a dent into the header.
- Stu Harmon
Re: Project "69 Twin TurboCharger" [Re: feets] #825900
05/03/11 03:47 AM
05/03/11 03:47 AM
Reno, NV
W
W
Reno, NV
Back from the dead..... I have been moving to a new house this past month so it has been a while sense I got and "Charger time". I did manage to find time to weld up one header. It is not totally done but I'll finish it up when I weld the waste gate and the seven sensor fittings........
You can see my "poor man's TIG" in the background of the first shot. That is what I'll be using for most of the joints......
I also spent some time cleaning the old turbos up... BTW, I know the paint wont last very long at all, but the stuff is some of the best exhaust paint I have found. It is John Deere "Muffler black" if you care...
That's all for now, I did order a few EGT probes to aid in the placement planing ahead.
Re: Project "69 Twin TurboCharger" [Re: Wilde Racing] #825901
05/03/11 09:55 AM
05/03/11 09:55 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Man I hope you plan on running those iron heads (or something exactly the same), Be a shame to mock all that up, use a set of aluminum heads and have none of that fit anymore.
Re: Project "69 Twin TurboCharger" [Re: Mr.Yuck] #825902
05/03/11 11:03 AM
05/03/11 11:03 AM
Reno, NV
W
W
Reno, NV
I hope the aluminum heads I plan on getting some day are not all that different. LOL
Re: Project "69 Twin TurboCharger" [Re: Wilde Racing] #825903
05/03/11 01:12 PM
05/03/11 01:12 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
you'd better get the stealths then.
Re: Project "69 Twin TurboCharger" [Re: Mr.Yuck] #825904
05/03/11 02:58 PM
05/03/11 02:58 PM
Reno, NV
W
W
Reno, NV
I thought there were so sort of issues with them?? How much different are the edlelbrock heads over stock?
Re: Project "69 Twin TurboCharger" [Re: feets] #825905
05/03/11 03:22 PM
05/03/11 03:22 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
same thought I had. very nice but loads of work.
I would recommend you split the flange in between cylinders and make sue the bolt holes are oversized. This will help keep the sealing by allowing some movement when they get hot plus eliminate any possible warping of the flanges
home of the
Sox and Martin Hemi Duster
Re: Project "69 Twin TurboCharger" [Re: HEMIFRED] #825906
05/03/11 04:12 PM
05/03/11 04:12 PM
Reno, NV
W
W
Reno, NV
I thought about splitting the flange. I wasthinking of splitting the front and rear cylinders off. I'll drill the holes out.
Re: Project "69 Twin TurboCharger" [Re: Wilde Racing] #825907
05/06/11 02:29 PM
05/06/11 02:29 PM
GA
Boosted Offline
Boosted  Offline
GA
Instead of Stealths you could always get the MP Stage 6 heads.... I love mine..
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
