OK guys need some "mini van" help with codes..... #825399
10/09/10 01:24 AM
10/09/10 01:24 AM
Sioux Falls SD
79volare Offline OP
79volare  Offline OP
Sioux Falls SD
My wife is having issues with her trans. in her 01 Town & Country van, I scanned the computer and it came up with 7 codes, I have looked all over and see nothing that is the same...the codes are:
PO732,733,734..PO171...PO700...PO442...PO455.....now I am not sure where to post this at, so If it is wrong sorry, this is the 2nd time I have posted in here, my brother...(hot air balloon pilot)does ALL THE TIME...so can some one please help......BTW her trans will not shift out of 1st gear....
Re: OK guys need some "mini van" help with codes..... [Re: 79volare] #825400
10/09/10 01:51 AM
10/09/10 01:51 AM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
Re: OK guys need some "mini van" help with codes..... [Re: Dakota_Don] #825401
10/09/10 01:56 AM
10/09/10 01:56 AM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
Re: OK guys need some "mini van" help with codes..... [Re: Dakota_Don] #825402
10/09/10 02:05 AM
10/09/10 02:05 AM
Sioux Falls SD
79volare Offline OP
79volare  Offline OP
Sioux Falls SD
Thank You Sir.....I found what I need....Thanks again!!!
