Valvetrain Magnum 5.9l #825206
10/08/10 07:18 PM
10/08/10 07:18 PM
Sarasota, Fl
siggie30 Offline OP
siggie30  Offline OP
Sarasota, Fl
I have purchased some springs and am curious what the stock magnum series valves weigh?
Mine are I: 106.35g
O: 95.78g
Also, literature suggests that stock retainer locks are 7 degree. Can I/should I upgrade to 8 degree (P4529218) locks since I have a warm engine? Will it affect install height?
I don't even have 1/2 lift, but the other 1/2 is nitroused.
Re: Valvetrain Magnum 5.9l [Re: siggie30] #825207
10/08/10 07:20 PM
10/08/10 07:20 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I have no clue what the original springs weigh.
Unless you're using an insane camshaft, I'd stick with the 7 degree.
- Stu Harmon
