Re: 5.9 Magnum Pistons [Re: Wedgeman] #823828
10/07/10 10:14 PM
10/07/10 10:14 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
The stock pistons on this motor were .070 in the hole, you could have them mill that much off the deck and use stock pistons and the readily available 1008 fel pro and you will get good quench and compression.
Re: 5.9 Magnum Pistons [Re: dfsmopars] #823829
10/07/10 10:18 PM
10/07/10 10:18 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
Somebody please tell me I am going to be really glad I built the Magnum instead of building my 318! Tell me that when I get this Magnum in my Charger I am going to be like a woman giving birth that soon all the pain will be erased by the joy!!
Well, you won't feel violated! That's for sure!
Re: 5.9 Magnum Pistons [Re: dfsmopars] #823830
10/07/10 10:28 PM
10/07/10 10:28 PM
Kentucky
dfsmopars Offline OP
Kentucky
Phew! Thanks everybody I feel better. I'll keep plodding along and figure this combination out with the help of your input.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
Re: 5.9 Magnum Pistons [Re: HotRodDave] #823831
10/07/10 10:28 PM
10/07/10 10:28 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
This is true, & thats not counting the dish (its deaper then the edge of the piston itself). I think acheiving 10.1 out of them with the closed chambered head should be very easy, especially if you deck the block some, don't know how pump gas friendly they would be at that level with iron heads, maybe good .
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: 5.9 Magnum Pistons [Re: joedust451] #823832
10/07/10 10:31 PM
10/07/10 10:31 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
10 to one with iron magnums is fine even with pretty mild cams, they are very detonation resistant with good quench.
Re: 5.9 Magnum Pistons [Re: dfsmopars] #823833
10/07/10 11:15 PM
10/07/10 11:15 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Your pain will become more acute when you realize you could have had a 440. sorry,kidding(sort of).
Re: 5.9 Magnum Pistons [Re: forphorty] #823834
10/07/10 11:32 PM
10/07/10 11:32 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
I race a guy at my track, he has a 440 in a dart with aftermarket lower components, more cam, more gear, & i think more stall, don't know what his problem is, but we run "dead on", he keeps accuseing me of running the nitrous , i told him flat out, you "WILL" know when i run the nitrous . & the funny thing is, he has another 440 dart that runs 11.0s.
Re: 5.9 Magnum Pistons [Re: forphorty] #823835
10/07/10 11:48 PM
10/07/10 11:48 PM
Kentucky
Kentucky
I have a 440! I am kinda partial to some nice handling to go along with some respectable power. I have 318, a 440 and a 360 Magnum and I chose the magnum for several reasons. I may have to sale everything else to finance my decision.
Re: 5.9 Magnum Pistons [Re: dfsmopars] #823836
10/08/10 12:16 AM
10/08/10 12:16 AM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
In spite of my above comment, i've been considering a 5.9 myself. I own two B bodies with big blocks, but a couple years ago i bought a 72 duster with a 318. Been fooling with it on the cheap. I have been doing the stuff that needs to be done regardless of the engine choice . Suspension,brakes frame connectors,etc. I have been following Joedust451s progress and have been pretty impressed. Also been reading everthing i can about the RHS heads. I now have the opportunity to buy an old 380 hp crate engine , incomplete(no lifters,pushrods)and condition unknown. So... in the future i may be a member of the 5.9 brigade myself.
Re: 5.9 Magnum Pistons [Re: forphorty] #823837
10/08/10 12:39 AM
10/08/10 12:39 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Thanks for the props forforty, I will say this, i'm a BB A body builder by heart, i can pretty much make/build a 440 dart/duster with little of nothing & it'll run the #s, but i'm sooooo impressed with this 360 "magnum" that i'm stoked, for a very very mild stock/used shortblock to run like this is amazing, & its damn near in the 7.9s in the 1/8 shifting at 5100, what that tells me is its a torque monster .
Re: 5.9 Magnum Pistons [Re: joedust451] #823838
10/08/10 02:39 AM
10/08/10 02:39 AM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
My goal for the duster is to have a mild comfortable driver that gets driven on the highway a lot. Will probably end up with 3.23s once i get a 8.75 built for it. Ac and stereo are in the plans also. A build similar to yours would work well . I can get the crate motor pretty cheap. Will probably get it and tear it down to see what is useable. The cam is a little hotter than i want and i would probably trade off the single plane. Since it has no lifters, are the factory replacements expensive? I think the spider is still there. Wondering if i might be better off just getting a good complete truck motor as you did, instead of the incomplete crate motor.
Re: 5.9 Magnum Pistons [Re: forphorty] #823839
10/08/10 06:50 AM
10/08/10 06:50 AM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
The factory replacement rollers are good stuff and only about 140 bucks for an entire set.
nothing wrong with them at all. They will be perfect for you.
Re: 5.9 Magnum Pistons [Re: forphorty] #823840
10/08/10 09:12 AM
10/08/10 09:12 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Like bignozzle said, the lifters aren't exspensive, & you can run chevy style roller rockers so you can save there too, If you can find a good used Magnum from a truck with fairly low miles & don't spend more then 4-500.00 then grab it, the only weak area with them is in the magnum heads, they tend to crack in-between the valves in the chambers, the end chambers are the worsed, what all comes with this crate motor your looking at & what do they want for it?
Re: 5.9 Magnum Pistons [Re: joedust451] #823841
10/08/10 09:28 AM
10/08/10 09:28 AM
Illinois
StrkrDart69 Offline
StrkrDart69  Offline
Illinois
If you are not in a big hurry and shop around at salvage yards, you can find magnums fairly cheap. I picked up a complete 5.2 magnum, complete with wiring harness, and everything on the engine, including alt. for $150.00 And it was in the shop on a pallet, I did not have to wait for them to pull it. I also found a 5.2 magnum in the local paper out of a 95 dakota with 40k miles on it for $250.00 And it came with the A518 trans! I thought about putting the trans in my Dart, but instead put it on craigslist for $250 and it sold the same day. The guy had wrecked his Dakota and planned on using the eng. and trans. and never did. Wanted it out of his garage. Also I have several sets of magnum heads and none of them are cracked. On my stroker in am running RHS X heads.
Re: 5.9 Magnum Pistons [Re: HotRodDave] #823842
10/08/10 09:57 AM
10/08/10 09:57 AM
Illinois
StrkrDart69 Offline
StrkrDart69  Offline
Illinois
I have 10.5 compression with .544 int lift .568 ex and no detonation on pump gas.
Re: 5.9 Magnum Pistons [Re: forphorty] #823843
10/08/10 10:08 AM
10/08/10 10:08 AM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
I wouldn't be in a big hurry to trade off that single plane intake. These Magnum engines really like those.
Re: 5.9 Magnum Pistons [Re: Duner] #823844
10/08/10 11:50 AM
10/08/10 11:50 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I have to agree on the single plane, the eddy air gap is a little better but I have the M1 single plane on mine and even with a comp XE268 cam stock converter and 2.76 gears it lacks nothing in the TQ department. If you stomp the gas right off idle it twists the body pretty good, feels like the tire is gonna come off the ground (it don't but it feels that way).
Stock magnum heads crack on 9 out of 10 heads but I have never ever seen it cause any problems. They just don't go into the water ports. I have even seen cracks on brand new castings.
Re: 5.9 Magnum Pistons [Re: HotRodDave] #823845
10/08/10 04:51 PM
10/08/10 04:51 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Sorry if i might have gotten this thread a little off topic. I do appreciate the info guys. Nice to know that the single plane is a pretty good intake for a mild street engine. Looks like i can get the engine for $200. Includes the intake and the finned alum valve covers, headers and some other misc. no lifters.
Re: 5.9 Magnum Pistons [Re: forphorty] #823846
10/08/10 06:15 PM
10/08/10 06:15 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
another option, look at diamond pistons PN 51420, they're stock 9cc dish 360 pistons, with a 1.667CH (.008" lower than the KB's)
2017 Grand Cherokee Overland
