I need to get this thing close as possible before I take it in for a front end shop. I just replaced the lower ball joints, etc, I was able to get the drive side pretty close Camber wise.
I simply just rolled the bolts offset to the furthermost most point to the inside, worked ok for the driver. passenger still has a noticeable lean to it.
Just wondering if there is something else I can do adjustment wise to help it out some. You can see the tire is leaning Positive camber, so it must be a good bit
