Re: Horn Relay -70 E Body??
[Re: RT_6_PakShaker]
#82384
07/02/08 08:35 AM
07/02/08 08:35 AM
Posts: 3,683 The Historic Hudson Valley
MONC
Thanks for the pics - always helpful ![](/ubbthreads/images/graemlins/thumbs.gif) So there is a difference between the horn relays from E to B body in 70. Guess it depends on where it is mounted. The terminals off the one I took off my B- body don't match up to the one for the E body. I'll have to buy a replacement and work forward from there. Thanks.
[Re: 70440+6bbl]
#82386
07/02/08 04:58 PM
07/02/08 04:58 PM
Posts: 556 Arkansas
GregGarner
Arkansas
Note also that there is a difference between 1970 Ebody horn relay and the 1971 Ebody horn relay. The 1971 one has a buzzer in it, but the 1970 one does not. (At least my 1970 TA Challenger has a different relay in it from my 1971 Challanger convertible.) Greg Garner www.rt-eng.com1-479-756-2757
[Re: GregGarner]
#82387
07/02/08 08:59 PM
07/02/08 08:59 PM
MONC
Well now I'm confused. Mine is in a 70 E body and the buzzer buzzes and is located on the fuse block. In the pics above it appeared there was a buzzer and a relay not one in the same unit. And I believe that is a 1970 model.
Had the wheel off today, hoping to find something burned or broken, but everything looks fine along with the contacts.
And my relay buzzes with the key in it, but I got no honk...
