Thin wall Mega Blocks #823617
10/06/10 09:49 PM
10/06/10 09:49 PM
Deland, Florida
biff426 Offline OP
biff426  Offline OP
Deland, Florida
I remember a post thought I saved the info but can't find it now someone posted casting numbers or some identifing numbers for thin wall mega blocks I know some were thin in the early years I tried the search funtion with no luck
Re: Thin wall Mega Blocks [Re: biff426] #823618
10/06/10 09:59 PM
10/06/10 09:59 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
PM Bob George on this board, he knows the casting numbers, along with most any other thing you might have questions on
Re: Thin wall Mega Blocks [Re: Bob_Coomer] #823619
10/06/10 10:07 PM
10/06/10 10:07 PM
Newfoundland,Canada
avenger572 Offline
avenger572  Offline
Newfoundland,Canada
The one im using has a sticker on the rear of the block that says,DO NOT EXCEED 4.500 BORE .I guess thats the reason,must be thinner than normal. Its a 572cu,572 heads and 350 nos and doesn't seem to have a problem with this . ????
Re: Thin wall Mega Blocks [Re: avenger572] #823620
10/07/10 11:15 AM
10/07/10 11:15 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Later thin wall blocks were stickered do not exceed 4.310 or other demensions.If the sticker is gone you must sonic test.Be cautious and check all bores at all locations,some blocks may have only a few thin cylinders resulting from core shift.All early blocks cast in the early 1990s with stamped serial numbers 360 or lower were junk.
