Anyone make a standalone that'll work on a boosted 5.7? #823421
10/06/10 01:18 PM
10/06/10 01:18 PM
Louisville, KY.
Scottmon Offline OP
Scottmon  Offline OP
Louisville, KY.
I've been looking around to see if anyone makes a standalone to work with the distributorless ignition on a boosted 5.7. FAST, MP, XV, etc makes standalones for normally aspirated system, but boosted, forget it.
I like the SDS stuff, but they only do distributorless up to 6 cylinders.
Anyone get Megasquirt to work with something like this????
Re: Anyone make a standalone that'll work on a boosted 5.7? [Re: Scottmon] #823422
10/06/10 03:03 PM
10/06/10 03:03 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
You can try posting over on the megasquirt forums msefi.com there have been plenty of boosted V8's done with megasquirt. Really if you hang an edis-8 trigger wheel on it, megasquirt won't know the difference between a 5.7 and any other engine it's been hooked up to. However I seem to recall reading something about a new code version for the megasquirt units that allows you to use the stock 5.7 hemi crank sensor but it was a couple years ago that I read that and I'm not sure on the specifics of it. The code variant to do the stock sensors on the 5.7 might be based off the msextra.com forums.
Speaking of edis-8, I would assume SDS would be able to run an edis-8 equiped 5.7 hemi...?
Re: Anyone make a standalone that'll work on a boosted 5.7? [Re: DaytonaTurbo] #823423
10/06/10 03:14 PM
10/06/10 03:14 PM
Louisville, KY.
Scottmon Offline OP
Scottmon  Offline OP
Louisville, KY.
yeah, I'm thinking EDIS-8 from the local pick-n-pull would do the trick for the ignition side.
Looks like Megasquirt in my future!
I think the MS III might be the one that can use the 5.7 crank sensor, but from what I've read it's still in beta
SDS will only run up to 6 cyl distributorless.
If I'd stuck with a 360 Magnum SDS would be getting my money for an EM-4 E/MSD.
Re: Anyone make a standalone that'll work on a boosted 5.7? [Re: Scottmon] #823424
10/06/10 03:22 PM
10/06/10 03:22 PM
Amarillo, Texas
BBR Offline
BBR  Offline
Amarillo, Texas
MS3 is available.
http://www.diyautotune.com/
Matt Cramer runs that site. I bet he would know the ins and outs since he is a mopar guy.
I ran an MS1extra on my 545" BB Ranger and loved it.
Drag Week 2011 - 77th place - DD
Drag Week 2012 - 2nd place SRBB N/A
Drag Week 2014 - Kapooya
RMRW 2018
RMRW 2020
Re: Anyone make a standalone that'll work on a boosted 5.7? [Re: BBR] #823425
10/06/10 03:28 PM
10/06/10 03:28 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
aed
Re: Anyone make a standalone that'll work on a boosted 5.7? [Re: joshking440] #823426
10/06/10 04:26 PM
10/06/10 04:26 PM
New Brunswick, Canada
TrxR Offline
TrxR  Offline
You migth also look at FAST XFI , BS3 and the two new Holley systems.
Re: Anyone make a standalone that'll work on a boosted 5.7? [Re: TrxR] #823427
10/06/10 05:09 PM
10/06/10 05:09 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
I meant AEM..... sorry
Re: Anyone make a standalone that'll work on a boosted 5.7? [Re: BBR] #823428
10/06/10 05:34 PM
10/06/10 05:34 PM
Manitoba, Canada
Manitoba, Canada
MS3 is available.
Yes MS-3 has been officially released. Has some nice toys and can do sequential injection. I have MS-2 which I bought several years ago and haven't gotten to installing yet. Matt Cramer is a good resource, back when I was getting into the MS stuff I noticed he was fairly active on the msefi forums.
Re: Anyone make a standalone that'll work on a boosted 5.7? [Re: DaytonaTurbo] #823429
10/07/10 10:13 AM
10/07/10 10:13 AM
IL
furious70 Offline
furious70  Offline
IL
he's also on theturboforums
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Anyone make a standalone that'll work on a boosted 5.7? [Re: Scottmon] #823430
10/07/10 10:47 AM
10/07/10 10:47 AM
MI
Blown69 Offline
mopar addict
Blown69  Offline
mopar addict
MI
Mopar P5153921 Controller and Harness will work with boosted apps, also is lap top programmable
Re: Anyone make a standalone that'll work on a boosted 5.7? [Re: Blown69] #823431
10/07/10 06:59 PM
10/07/10 06:59 PM
Grande Prairie, Alberta, Can.
CW25 Offline
CW25  Offline
For a rediculus ammount of money...
11.67@118 1.88 60' with only 7-8 lbs of boost. Turbocharged, megasquirted, 407 BB, 440 source heads, roller cam, 9:1 comp. http://s292.photobucket.com/albums/mm14/beansgracie
Re: Anyone make a standalone that'll work on a boosted 5.7? [Re: CW25] #823432
10/07/10 08:42 PM
10/07/10 08:42 PM
MI
Blown69 Offline
mopar addict
Blown69  Offline
mopar addict
MI
Hummm (3,165.00)$165 more than a FAST XFI http://cgi.ebay.com/ebaymotors/FAST-3010...sQ5fAccessories I don't think that's ridiculous, I run this on my set-up and it works flawless
Re: Anyone make a standalone that'll work on a boosted 5.7? [Re: Blown69] #823433
10/07/10 09:55 PM
10/07/10 09:55 PM
CW25 Offline
CW25  Offline
I doubt it is as flexible as the FAST system making it not worth near the money but I havn't researched it. I went MSII for about $1400. My system won't support a next gen hemi without a EDIS 8 but a MSIII will with sequential if you want it but costs go up. Still doubt you would hit much over 2K though.
Re: Anyone make a standalone that'll work on a boosted 5.7? [Re: CW25] #823434
10/09/10 01:50 PM
10/09/10 01:50 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
You could check out Electromotive http://www.distributorless.com/products/tec.php
Distributorless is what they have always done.
Kevin
Re: Anyone make a standalone that'll work on a boosted 5.7? [Re: Twostick] #823435
10/09/10 11:25 PM
10/09/10 11:25 PM
Reno, NV
W
Wilde Racing Offline
W
Reno, NV
New guy here, but a few people have has success running a gm computer with their 5.7's. The gm unit is tunable but some what limited for boost. I have tuned a few turboed and supercharged GM trucks including my own using HPTuners. Let me know if you want more info on this option, I might even beable to point you in the right derection for parts.... One thing is it would be cheap...
Re: Anyone make a standalone that'll work on a boosted 5.7? [Re: Wilde Racing] #823436
10/10/10 09:23 AM
10/10/10 09:23 AM
Louisville, KY.
Scottmon Offline OP
Scottmon  Offline OP
Louisville, KY.
Pretty much decided to go with Megasquirt 3, kind of like the Linux of engine controllers 5.7 uses the same trigger wheel as the Neon and MS3 can use the cam sensor as well. It'll do sequential or bank/batch fire on the injectors, works with a 3 bar MAP, fires COP natively...lots of good options. Not plug-n-play though, but I've had enough experience with 2.2 Turbo Dodges over the years to know what needs to go where and how on setup.
Re: Anyone make a standalone that'll work on a boosted 5.7? [Re: Scottmon] #823437
10/11/10 11:13 PM
10/11/10 11:13 PM
Manitoba, Canada
Manitoba, Canada
Yes definitely not plug and play, however the MS stuff can be fun. I bought the basic MS-2 controller and am about 1/2 way done the process of assembling it myself. If I had to do it all over again I would just buy the preassembled version with the 3.57 board. The 3.57 is all machine assembled unlike the other ones that either you or someone else has soddered together by hand.
