Re: Noise coming from differential. Opinions please?
[Re: Moparguy383]
#823240
10/06/10 12:45 PM
10/06/10 12:45 PM
Posts: 75,005 U.S.S.A.
JohnRR
U.S.S.A.
Car has a 489 case 8 3/4 rear with 3.55's on a cone style sure grip. Sometimes when backing up, the car will make a dull clunk and it comes from the rear. It makes this noise under power, but also has made it with the driveshaft off and being pushed. Where should I be checking? Axle bearings, center section or ?? Is this something the cone style sure grip does? It has been a long time since I have used anything other than the clutch style sure grip. Any advice is appreciated.
Thanks, Reid.
That doesn't sound good , is it making the clunk going straight or are you making a turn ?
just say no to cone types
[Re: DoctorDiff]
#823242
10/06/10 02:51 PM
10/06/10 02:51 PM
Posts: 4,041 michigan woods
imfixinmopars426
michigan woods
Sometimes sure-grips stick when backing up.
You may need to change the fluid and add 1 bottle of friction modifier.
my supercoupe rear is noisy,it has a cone type s/g,too.pops when you backup,and acts like the "clutches" are sticking.
