Page 4 of 6 1 2 3 4 5 6
Re: Pros and Cons for 284/484 cam [Re: Mr.Yuck] #82300
07/03/08 02:54 PM
07/03/08 02:54 PM
Anyone run a .484 with a 4-speed?
Yep..
One should have at least a 3.55 rear end, we ran it with a 3.91.
Just my ..
I'm probably going to run either 3.91 or 4.10's.
Run a 509 w/ a 4 speed and 4.10's and you'll be close to 11's. 484's and 509's have the same "drivability" so you might as well use the big bump stick.
I already have the .484
Re: Pros and Cons for 284/484 cam #82301
07/03/08 03:06 PM
07/03/08 03:06 PM
KY
65pacecar Online happy
65pacecar  Online Happy
KY
I am running it in a 65 Sport Fury, 383 auto, 11.25:1 Compression (True), 906 Heads that have been worked a little, 3.91 Gears and I am very happy with it and the car doesn't do too bad on gas, around 14 or so unless I am getting on it. I have ran a few cars with this cam, always been happy with it.
Re: Pros and Cons for 284/484 cam [Re: 65pacecar] #82302
07/03/08 03:43 PM
07/03/08 03:43 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Ran it in a stock 383 with 452 heads and 9.5 comp. It had the normal bolt on's of the RPM intake and a 750 DP. Had headers and a 3000 tight TA convertor with 3.91's. In my sons Dart at 3600 lbs with him in it the Dart ran as fast as 12.31 @ 110 ! This cam will make good power and run very good in the right combo. But I would not use it in a stock 383 or 440 with a stock convertor and 3.55's. Most people who dont like it just did not run it in the right combo. Ron
Re: Pros and Cons for 284/484 cam [Re: 383man] #82303
07/03/08 05:40 PM
07/03/08 05:40 PM
... Most people who dont like it just did not run it in the right combo. Ron
EXACTLY
Re: Pros and Cons for 284/484 cam [Re: VITC_GTX] #82304
07/03/08 05:51 PM
07/03/08 05:51 PM
organ
maximum entropy Offline
organ
i built a 383 for a guy with that cam and 1.6 rockers. we started with a stock converter and it was not so good. with a looser converter it's much better. yeah, it's an ancient design, but with appropriate compression and converter. it's a blast. it runs crazy strong for a 383 and sounds surprisingly wicked. just make sure about that converter, among other things.
Re: Pros and Cons for 284/484 cam #82305
07/04/08 09:43 AM
07/04/08 09:43 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
EXACTLY
what's the right way??? I'll tell you, 3000 stall, nice headers, high compression, decent heads and 3.91's or better. So he has a stcok stall and 3.55's is it going to run well?
Re: Pros and Cons for 284/484 cam [Re: VITC_GTX] #82306
07/04/08 02:02 PM
07/04/08 02:02 PM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
If I keep my stock compression, 28" tires, 3.55's, stock HP exhaust manifolds with 2 1/2" pipes and the 284 cam and put in a converter that flashes to 3000-3500 would that work for me?
Re: Pros and Cons for 284/484 cam [Re: VITC_GTX] #82307
07/04/08 02:25 PM
07/04/08 02:25 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Sure it will work. The point is there are other cams that may work better, although the purple shaft/lifter kits are priced better than the Comp and Hughes cams which might alse require stiffer valve springs.
Re: Pros and Cons for 284/484 cam [Re: 451Mopar] #82308
07/04/08 02:42 PM
07/04/08 02:42 PM
Grand Rapids, MI
11secondC Offline
11secondC  Offline
Grand Rapids, MI
I ran it in a near 4500 lb '67 VIP. Last time I ran it with a worn out 413, RPM, 750 afb, 1.75" headers, 3.55's and a 2400 stall...best it ran was 14.17 @ 97 mph. It had a nice lope and would boil the tires at will.
Re: Pros and Cons for 284/484 cam [Re: 451Mopar] #82309
07/04/08 02:43 PM
07/04/08 02:43 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
I'm sure I could do better with another cam like you said, but I will need a converter for another cam too.
I was hoping not to crack the motor open at all. It's easier for me to change out the torque conveter, it only takes me an hour or 90 minutes.
Sounds like I need to change out the converter first, if that doesn't light a fire under the car then I will consider a new cam. I'm convinced this car is build to run a lot quicker/faster than it is. My small block Demon will blow it's doors off right now.
Re: Pros and Cons for 284/484 cam [Re: VITC_GTX] #82310
07/04/08 03:29 PM
07/04/08 03:29 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Oops, sorry for getting off the original topic.
Yes, a high stall converter will help, and likely be needed with other simular sized cams.
I have been really happy with my old Dynamic 10" race converter. The newer 9.5" converter is supposed to be even better.
As mentioned earlier, recurving the distrubitor for greater initial advance should also help.
If you have a reasonably priced chassis dyno in your area, it may be worth it to just make a baseline run with 02 sensors so you can see if the air/fuel curve is close or way off. I have seen some really nice looking big buck cars run on the chassis dyno that were so out of tune it makes you cringe.
To me, it makes no sense to throw expensive parts at a car if your not going to tune them to work right. The chassis dynos around here charge between $50 and $100 to make several baseline runs, and usually about the same amount per hour for tuning time.
The alternative is test-n-tune at the drag strip.
Tuning at the strip works, but there are so many cars at the strip here, you don't get alot of runs.
Re: Pros and Cons for 284/484 cam [Re: 451Mopar] #82311
07/04/08 03:55 PM
07/04/08 03:55 PM
Pataskala, Ohio
GTX70sixpack Offline
Pataskala, Ohio
I run that cam in my GTX, 4spd and 3:54s and it works great. Bottom end and good MPG. Sounds too tame at idle though.
My sons running a 509 in a 360 4spd and 3:55s and it has good bottom end to (will ignite the tires with out dumping the clutch) and is a lot livelier than the 484 but MPG is horrible
65 Belvedere II Station Wagon
69 Coronet R/T convertible
70 GTX
70'cuda
99 Dodge Diesel dually 4X4
Re: Pros and Cons for 284/484 cam [Re: Mr.Yuck] #82312
07/04/08 05:41 PM
07/04/08 05:41 PM
EXACTLY
yup
i think you need to get off the
Re: Pros and Cons for 284/484 cam [Re: 451Mopar] #82313
07/04/08 06:06 PM
07/04/08 06:06 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
I did have FBO recurve my MP dizzy. I believe it's 18 initial and 35 total all in by 2500 rpm (plus or minus one or two degrees, I forgot exactly where it's at).
Re: Pros and Cons for 284/484 cam [Re: VITC_GTX] #82314
07/04/08 06:31 PM
07/04/08 06:31 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
LOL I'd rather do 3 cams then pull one trans. The 484 + moni's + stock convert + 3.55's = slow. Just get a good cam and leave the converter alone. You'll still need 3.91's even w/ a converter not to mention a good converter is $300+ and a set of 3.91's is anoher $190 just for ring/Pinion.
Re: Pros and Cons for 284/484 cam #82315
07/04/08 06:35 PM
07/04/08 06:35 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
EXACTLY
yup
I think you need to get off the
Tell you what you put together a stockish 440 w/ mani's, stock stall, 484 cam and 3.55's I'll do the same with and use a el-cheapo special from Summit or Jegs and spot you a light or two.
Re: Pros and Cons for 284/484 cam [Re: VITC_GTX] #82316
07/04/08 06:36 PM
07/04/08 06:36 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
You need about 36-38* total
Re: Pros and Cons for 284/484 cam [Re: Mr.Yuck] #82317
07/04/08 06:38 PM
07/04/08 06:38 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Funny how folks are different. I would much rather swap out a converter than do a cam swap
Of course it probably helps that I have a two post lift in the shop. I would hate to do a tranny swap on jack stands again.
Re: Pros and Cons for 284/484 cam [Re: Mr.Yuck] #82318
07/04/08 07:10 PM
07/04/08 07:10 PM
EXACTLY
yup
why? you just a sucker for punishment? or is that just howz yah like it.
Re: Pros and Cons for 284/484 cam #82319
07/05/08 09:08 AM
07/05/08 09:08 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
EXACTLY
yup
Nope just been there w/ the 509 and 484 in stockish 440's. a stock magnum cam works better.
