window regulator rebuild kits...available? #821523
10/04/10 01:23 PM
10/04/10 01:23 PM
Austin, Texas
Seank Offline OP
Seank  Offline OP
Austin, Texas
Car 68 cuda convertible.
The drivers side (of course) window regulator shaft bushing is bad but the gears are ok etc. Does anyone make a rebuild kit or should I just hackup some 4 door regulator for parts as the little pot that holds the shaft etc. is only held in by 3 rivets?
Did a web search and could find none.
Sean
Re: window regulator rebuild kits...available? [Re: Seank] #821524
10/04/10 04:59 PM
10/04/10 04:59 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Haven't had to make this repair so I'm shooting from the hip...
Check Mcmaster.com for bronze flanged bushings, maybe there's soemthing there that will work. Don't rule out a nylon bushing either.
