how to tell if its hemi carb? #821094
10/03/10 09:17 PM
10/03/10 09:17 PM
jacksboro,tn
1bad318 Offline OP
1bad440
1bad318  Offline OP
1bad440
jacksboro,tn
i have a chance to buy a tunnel ram and 2 carter avs for 200 bucks.the guy says they are hemi carbs.how can i tell?
Re: how to tell if its hemi carb? [Re: 1bad318] #821095
10/03/10 09:19 PM
10/03/10 09:19 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
by the numbers,,,,
I am truckless..
Re: how to tell if its hemi carb? [Re: 1bad318] #821096
10/03/10 09:55 PM
10/03/10 09:55 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
If they are AVS carbs they are not hemi carbs , the hemi only used the AFB .
Re: how to tell if its hemi carb? [Re: 1bad318] #821097
10/03/10 11:42 PM
10/03/10 11:42 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Hemi AFB's have the small air cleaner throat and are right side fuel inlets, after that it's time to check the #'s. And no AVS on a Street Hemi.
Sheldon
Re: how to tell if its hemi carb? [Re: RUNCHARGER] #821098
10/04/10 12:39 AM
10/04/10 12:39 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
To make it easy on yourself have the guy give you the numbers stamped into the faces of the passenger side front mounting feet. Post them here and we'll tell you what they are. BTW, I agree with all of the above, AFB's only, Small tops only. The carbs did vary slightly in physical appearance over the years, you need the numbers. Here's a pic of an original set of 1966 Hemi carbs.
Re: how to tell if its hemi carb? [Re: ScottSmith_Harms] #821099
10/04/10 12:40 AM
10/04/10 12:40 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
1968 Hemi Carbs
Re: how to tell if its hemi carb? [Re: ScottSmith_Harms] #821100
10/04/10 12:41 AM
10/04/10 12:41 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
1970 Hemi Carbs
Re: how to tell if its hemi carb? [Re: ScottSmith_Harms] #821101
10/04/10 12:49 AM
10/04/10 12:49 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Here's what the stampings look like, the 4 digit number followed by the "S" is the number you want, the single letter/number is the date code. In this case it is a 1968 Hemi Carb #4430 (front carb, either transmission) the date, K7 = October 1967 production.
Re: how to tell if its hemi carb? [Re: ScottSmith_Harms] #821102
10/04/10 05:00 AM
10/04/10 05:00 AM
jacksboro,tn
1bad318 Offline OP
1bad440
1bad318  Offline OP
1bad440
jacksboro,tn
ok,i was wrong.the carbs are afb.they look just like the 68 carbs,down to the vacum diaphram on the side of the carb.one has a 2x marking on the right side top.
Re: how to tell if its hemi carb? [Re: 1bad318] #821103
10/04/10 09:45 AM
10/04/10 09:45 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
The markings on the tops have nother to do with i.d. you need the numbers off the feet, and btw, other non Hemi AFB's look allot like the Hemi carbs (including the dash pot) you can not go by appearance alone.
