Re: 1947 Dodge or Fargo Truck [Re: fstfish66] #820502
10/17/10 10:48 PM
10/17/10 10:48 PM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
I'm thinking an F,M & J subframe will be too wide for that era truck unless you move the fenders out. I had to move the fenders on my 35 Dodge sedan, and the tires were close to the fenders on my 54 pickup with 7" squad car wheels.
When you said "minus t bars", does that mean you want a Mopar suspension without torsion bars at all?
Your going to be pretty limited to something available before 57, or something newer with struts. The early stuff had a pretty good kick up at the front wheels to provide suspension travel. If you intend on using the older stuff, I'd probably go with an original frame and leaf springs. Newer stuff tends to have the suspension above the frame, so their frames were level, or almost level around the wheels. If your thinking newer stuff, I think I'd look under something like a 1st gen Intrepid. They were boxed tube frame with all components bolted above the frame. I think the struts would fit under the fenders easily. Wonder what's under the rear drive newer Chargers and Challengers, you would not have to modify the spindles due to the front drive like an Intrepid. Gene
Re: 1947 Dodge or Fargo Truck [Re: poorboy] #820503
10/18/10 03:19 AM
10/18/10 03:19 AM
NORTHERN CA
HUSTLESTUFF Offline
HUSTLESTUFF  Offline
NORTHERN CA
minus t-bars was in reference to something like an altercation. Mopar control arms, spindles, brakes with coil springs and a rack and pinion. Just a thought to see if anyone has done that. Mike
Re: 1947 Dodge or Fargo Truck [Re: HUSTLESTUFF] #820504
10/18/10 11:26 AM
10/18/10 11:26 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
2 brothers that i know in MD,, some how adapted the front suspension and steering from a C body chyrsler to work under both there rods,,one is a 41 plymouth,,the other is a 35 ply sedan trunk back,,
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: 1947 Dodge or Fargo Truck [Re: fstfish66] #820505
10/18/10 04:58 PM
10/18/10 04:58 PM
Moncton, New Brunswick
hemidart1 Offline
hemidart1  Offline
I would seriously measure up a long box S-10 chassis. All the suspension stuff is readily available and the swap makes the truck drive like a brand new one.
Forget trying to weld on C-body parts etc...
mount the body and cab on a frame that is ready to rock and that can be picked up at a wrecking yard for nothing. that's my
My buddies International 440-4speed on a S-10 chassis
then make your own motor mounts and drop in the Mopar engine.
1967 Hemi GTX
1969 Chrysler 300
Re: 1947 Dodge or Fargo Truck [Re: hemidart1] #820506
10/19/10 05:19 PM
10/19/10 05:19 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
One thing I've been told and seen myself is if you want a handling complete front suspension, look at race car stuff. Modifieds and other full chassis stuff. You gotta find someone that is well versed in them or do a bunch or learning though.
Street rod stuff is sold once and priced accordingly. Race stuff is as good or better, and is priced so the guy can put his car back together for next weekend.
http://www.speedwaymotors.com/Race-Car-Springs.html
Re: 1947 Dodge or Fargo Truck [Re: RodStRace] #820507
10/20/10 07:27 AM
10/20/10 07:27 AM
NORTHERN CA
HUSTLESTUFF Offline
HUSTLESTUFF  Offline
NORTHERN CA
I've definitely been looking at Speedway, but need to get some blueprints or similar for the mounts. I'd love to use tubular arms with a mopar ball joint for the uppers and a round tube lower with a strut rod and coil springs for the lower. I just need to know where to build the brackets for attachment and build a support for the coil over shocks. Would like to use Mopar spindles as I have a Wilwood 12.19" brake kit for B-body drum spindles. I may just have to get a book and and angle finder. Mike
Re: 1947 Dodge or Fargo Truck [Re: hemidart1] #820508
10/22/10 01:08 AM
10/22/10 01:08 AM
SK,Canada
gregsrt Offline OP
gregsrt  Offline OP
SK,Canada
I like that old International, if one ever shows up for sale around here I'm going to get it
An association of men who will not quarrel with one another is a thing which has never yet existed, from the greatest confederacy of nations down to a town meeting or a vestry. Thomas Jefferson
Re: 1947 Dodge or Fargo Truck [Re: gregsrt] #820509
11/24/10 12:43 AM
11/24/10 12:43 AM
montana
llklein Offline
llklein  Offline
montana
heres my 39 dodge im working on
Re: 1947 Dodge or Fargo Truck [Re: llklein] #820510
11/24/10 10:54 AM
11/24/10 10:54 AM
Ontario Canada
Webster Offline
Webster  Offline
Ontario Canada
Sweet!!! Thats is Nice
Re: 1947 Dodge or Fargo Truck [Re: llklein] #820511
11/25/10 09:42 AM
11/25/10 09:42 AM
moparx Online content
moparx  Online Content
that IS kool ! more info please !
Re: 1947 Dodge or Fargo Truck [Re: hemidart1] #820512
11/25/10 11:30 AM
11/25/10 11:30 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Picture of the old International brought back some memories when dad drove them. Also called them " cornbinders " great unusual ride.
Re: 1947 Dodge or Fargo Truck [Re: llklein] #820513
11/25/10 01:01 PM
11/25/10 01:01 PM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline
Mopar Ron  Offline
I agree with webster, thats a cool truck do you have more pics of it?
Re: 1947 Dodge or Fargo Truck [Re: Mopar Ron] #820514
11/25/10 05:49 PM
11/25/10 05:49 PM
montana
llklein Offline
llklein  Offline
montana
thanks guys.its chopped 5",took 6" off the rockers,channeled 4",and when i chopped it i moved the cowl back aprox 3" so the roof would line back up,then took the same amount off the rear of the doors.i built the chassis and used a speedway 6"drop front axle kit.i used a 68 dart manual steering box and set it up for cowl steering.used a 9 1/4" posi .plans for the engine are a 512 stroker kit and aluminum heads with a comp hyd roller.
i really like the willys clip on the dodge.
Re: 1947 Dodge or Fargo Truck [Re: llklein] #820515
11/25/10 05:52 PM
11/25/10 05:52 PM
montana
llklein Offline
llklein  Offline
montana
few more
Re: 1947 Dodge or Fargo Truck [Re: llklein] #820516
11/25/10 05:57 PM
11/25/10 05:57 PM
montana
llklein Offline
llklein  Offline
montana
Re: 1947 Dodge or Fargo Truck [Re: llklein] #820517
11/26/10 01:13 AM
11/26/10 01:13 AM
Ontario Canada
Webster Offline
Webster  Offline
Ontario Canada
That is alot of Nice Work
Re: 1947 Dodge or Fargo Truck [Re: Webster] #820518
11/26/10 03:15 AM
11/26/10 03:15 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
i agree kool man
2015 cherokee
2013 R/T classic
Re: 1947 Dodge or Fargo Truck [Re: Webster] #820519
11/26/10 02:37 PM
11/26/10 02:37 PM
Mopar Ron Offline
Mopar Ron  Offline
very cool truck
