Re: 1947 Dodge or Fargo Truck
[Re: fstfish66]
#820502
10/17/10 10:48 PM
10/17/10 10:48 PM
Posts: 10,629 Freeport IL USA
poorboy
Freeport IL USA
I'm thinking an F,M & J subframe will be too wide for that era truck unless you move the fenders out. I had to move the fenders on my 35 Dodge sedan, and the tires were close to the fenders on my 54 pickup with 7" squad car wheels.
When you said "minus t bars", does that mean you want a Mopar suspension without torsion bars at all?
Your going to be pretty limited to something available before 57, or something newer with struts. The early stuff had a pretty good kick up at the front wheels to provide suspension travel. If you intend on using the older stuff, I'd probably go with an original frame and leaf springs. Newer stuff tends to have the suspension above the frame, so their frames were level, or almost level around the wheels. If your thinking newer stuff, I think I'd look under something like a 1st gen Intrepid. They were boxed tube frame with all components bolted above the frame. I think the struts would fit under the fenders easily. Wonder what's under the rear drive newer Chargers and Challengers, you would not have to modify the spindles due to the front drive like an Intrepid. Gene
[Re: HUSTLESTUFF]
#820504
10/18/10 11:26 AM
10/18/10 11:26 AM
Posts: 1,757 levittown pa
fstfish66
levittown pa
2 brothers that i know in MD,, some how adapted the front suspension and steering from a C body chyrsler to work under both there rods,,one is a 41 plymouth,,the other is a 35 ply sedan trunk back,,
1966 barracuda prostreeter super charged 340(SOLD) 1940 dodge coupe 241 hemi street rod 2014 ram express hemi 4x4 dailey driver 2015 cherokee 2013 R/T classic
[Re: fstfish66]
#820505
10/18/10 04:58 PM
10/18/10 04:58 PM
Posts: 1,978 Moncton, New Brunswick
hemidart1
I would seriously measure up a long box S-10 chassis. All the suspension stuff is readily available and the swap makes the truck drive like a brand new one. Forget trying to weld on C-body parts etc... mount the body and cab on a frame that is ready to rock and that can be picked up at a wrecking yard for nothing. that's my My buddies International 440-4speed on a S-10 chassis then make your own motor mounts and drop in the Mopar engine.
1967 Hemi GTX 1969 Chrysler 300
[Re: hemidart1]
#820508
10/22/10 01:08 AM
10/22/10 01:08 AM
Posts: 2,431 SK,Canada
gregsrt
SK,Canada
I like that old International, if one ever shows up for sale around here I'm going to get it
An association of men who will not quarrel with one another is a thing which has never yet existed, from the greatest confederacy of nations down to a town meeting or a vestry.
Thomas Jefferson
[Re: gregsrt]
#820509
11/24/10 12:43 AM
11/24/10 12:43 AM
Posts: 35 montana
llklein
montana
heres my 39 dodge im working on
