Re: Optima battery charging [Re: Bryx512] #820255
10/03/10 09:51 AM
10/03/10 09:51 AM
gregsdart Offline
gregsdart  Offline
BRYX512, so if i can't (or won't) run an alternator, and have a 110 reserve bluetop, I would like to come up with a plan that can get me through later rounds, which are back to back.
To give you an idea of the draw on the battery for a run, I use an MSD digital seven, CCI command center, and run the mezier water pump only, no fan needed. I have a belt type fuel pump. The injection system takes a lot of cranking to get it going, and I start the motor about five times at about five seconds cranking each time. So the draw on the battery would be per round-
Water pump..... 5 min...7 amps
Ignition....... 5 min...2.5 amps avg
Starter..five starts at 5 sec each at 150 amps
Command center. 5 min .5 amps
(I will look up the draw for the pump, ign and command center and edit)
So my question is, to keep the battery at 12.75 volts or higher through out the run, what percentage of charge will it take and what is the best way to keep it there. Max draw during the run is 15 amps.
This is what I am thinking;
First off, I assume I should purchase the right charger to top off the battery before starting for the day, which will give me extra reserve. Then early rounds, where I have more time, use the good charger. Later rounds at a certain charge loss and beyond, use the bigger charger on start to give me enough reserve to get by?
Can I use my other charger on high during warm up to keep the battery charge high? Warm up takes about five to seven minutes with alky.
A battery does not charge in a linear manor, correct? Meaning, it restores less and less of the reserve as it approaches full charge? That is what I see with the gauge, at least.
Re: Optima battery charging [Re: gregsdart] #820256
10/03/10 10:34 AM
10/03/10 10:34 AM
Lehigh Acres, Florida
rickstershemi Offline
Easy Fix.....change over to an "Odyssey" dry cell and never look back
Rickster
Re: Optima battery charging [Re: gregsdart] #820257
10/03/10 10:52 AM
10/03/10 10:52 AM
Ohio
Todd Offline
Todd  Offline
Ohio
I been using red top optima batteries and found the $79 black and decker smart charger works great.
Re: Optima battery charging [Re: Thor500] #820258
10/03/10 11:11 AM
10/03/10 11:11 AM
malvern, ohio
3
3ddart Offline
3ddart  Offline
malvern, ohio
i think hot rod magazine did an article on charging agm batteries a couple of months ago. iirc it said something about hooking a flooded battery up beyond the agm to trip & trick the agm to take a charge. i skimmed over the article so i may have missed something lol.
Re: Optima battery charging [Re: 3ddart] #820259
10/03/10 11:29 AM
10/03/10 11:29 AM
Florida-West Coast
Thor500 Offline OP
Thor500  Offline OP
Florida-West Coast
I just ordered a Schumacher SC-8000A Speedcharge Charger/Maintainer from Amazon for like $80, at the very least I'll use it to top the battery off before racing, Also good for maintaining the car's that rairly leave the garage. I do run an alternator on the car but I get paranoid and usually charge between rounds especially when me and the kid double enter it.
Re: Optima battery charging [Re: gregsdart] #820260
10/03/10 12:13 PM
10/03/10 12:13 PM
Lincoln, NE
Bryx512 Offline
Bryx512  Offline
Lincoln, NE
Evil Spirit, Fred is correct, if the battery is in the factory location. ALL batteries are temp sensitive. Each have thier limits.
Gregsdart, Your thoughts on a fix would increase the life of your battery but using one charger like Crizila or Todd should do the same thing. Most "Smart" chargers have AGM charging abilities and can fast charge.
Rickster, the odyssey is also an AGM. They chose to use flat plates instead of a lead coil design. The term "dry" can really be used for all AGM batteries as there is no free flowing fluid. I avoid that term due to the fact there is a type of battery that IS truly dry. It has little more than lead and calcium powder.
All of the batteries mentioned are great! As I said earlier, every battery is built with a specific purpose in mind. In most cases, the battery that everyone is currently using will continue to "do the job". Battery life is my real concern.
Re: Optima battery charging [Re: Bryx512] #820261
10/03/10 12:54 PM
10/03/10 12:54 PM
mi
RATPATROL Offline
RATPATROL  Offline
mi
i have a optima yellow (5yrs old) sears 2/10/50 battery charger that has two settings, conventional low maintenance and maintenance free deep cycle. i think the deep cycle setting charges the battery to a higher voltage which i assume could heat the battery more, should i not use the deep cycle setting?
Re: Optima battery charging [Re: RATPATROL] #820262
10/03/10 01:20 PM
10/03/10 01:20 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
why would you run a deep cycle battery with an alternator??????????
All of my redtops were in racecars a minimum of 4-5 years charging with a little black and decker smart charger.
Re: Optima battery charging [Re: MegaDart] #820263
10/03/10 01:35 PM
10/03/10 01:35 PM
Lincoln, NE
Bryx512 Offline
Bryx512  Offline
Lincoln, NE
If we are still talking about Optima's only, the starting/ charging Red top can be used as a deep cycle. The same in reverse the Yellow and Blue tops can be used with an alternator. They will handle it better than most others but you will remove a certain amount of life. Flooded batteries can NOT be interchanged!
Properly maintained and in a good environment (no corrosion)a performance battery, that is proper for the situation, can last as long as 10- 12 years.
Re: Optima battery charging [Re: Bryx512] #820264
10/03/10 02:49 PM
10/03/10 02:49 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
This is true. I use two Red tops, and they turned 10 this year. I rotate all my batteries to my Deltron Battery Tender Plus each week. (A great product) I'm always amazed how little time it takes to get to "maintain" with those Optima's. Every once and awhile, I'll crank the car with each one individually, just to make sure I'm not crazy. I have read internet stories about the company being purchased, and that the new product isn't as good? Any truth, or just another internet rumor?
Re: Optima battery charging [Re: Bryx512] #820265
10/03/10 03:43 PM
10/03/10 03:43 PM
Ohio
3404 Offline
3404  Offline
Ohio
I teach battery technology so I think I can bring some light to this subject. Bear with me, the explanation is long...
Optima batteries are designed in a way that they should not receive greater than 7 amps of charge. They will deal with a greater amount for a SHORT period of time but is NOT recommended! The reason for the limit on charging is due to it's construction. Each spiral cell is a continuous roll of perforated lead covered on both sides as it's rolled up with fiberglass matting and paste. Once they are installed in the case and connected to the posts, a specific amount of water and acid is added. The solution is absorbed by the matting and held next to the rolled lead plates. Now, the reason for the limiting of charging is due to potential evaporation of the water in the solution. If over charged, the water evaporates and once the pressure in the case reaches a certain pressure, the release valves in the top of the case (the two "stone" looking things) open. Once the pressure is released, and an amount of water leaves with it, the life of the battery is done (the valves do NOT reset).
There are now chargers that are designed for AGM (Absorbed Glass Material) batteries.
I hope this helps
Great info here, I use a "automatic" charger and one year I had one (I run two red tops)get so hot while charging that it was puffing smoke out of one the top vents. It was running at around 20 amps when I first turned it on and normally it drops down pretty fast but sometimes these take can take a while to charge to 100%. The battery is still working fine but that one really scared me when it got that hot, it was pretty much at a boil.
Re: Optima battery charging [Re: Leigh] #820266
10/03/10 04:59 PM
10/03/10 04:59 PM
Lincoln, NE
Bryx512 Offline
Bryx512  Offline
Lincoln, NE
Optima was purchased by Johnson Controls (Interstate batteries) in 2000. I personally am not aware of any issues. Any time I have had someone complain about them getting a "bad" battery, it ends up being an alternator that is too small, over charging or corrosion in the wiring.
Re: Optima battery charging [Re: 3ddart] #820267
10/03/10 05:23 PM
10/03/10 05:23 PM
Kirkland, Washington
Pacnorthcuda Offline
That technique is for charging a deeply discharged Optima with a conventional charger. You're not tricking the battery but rather the charger into giving a charge.
A deeply discharged Optima has very high internal resistance, some 'ordinary" chargers see this (or more precisely DON'T see it) and fail to provide current. The parallel battery serves as a load so that the charger works, once the Optima is no longer deeply discharged (and its internal resistance drops) it can be removed from the circuit and the charger will charge the Optima.
Re: Optima battery charging [Re: Pacnorthcuda] #820268
10/03/10 05:57 PM
10/03/10 05:57 PM
malvern, ohio
3
3ddart Offline
3ddart  Offline
malvern, ohio
thanks cuda, i hoped someone would step-up and explain it for the masses.
Re: Optima battery charging [Re: Bryx512] #820269
10/03/10 07:46 PM
10/03/10 07:46 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
So with that said you would be better served to run the red tops for more CCA's right?
Re: Optima battery charging [Re: MegaDart] #820270
10/03/10 08:28 PM
10/03/10 08:28 PM
Lincoln, NE
Bryx512 Offline
Bryx512  Offline
Lincoln, NE
If you are running without an alternator, run a Yellow or Blue top. You are looking for reserve capacity not CCA. Just my
