Another Cal Track Question???? #820136
10/02/10 08:21 PM
10/02/10 08:21 PM
Q
quick77rt Offline OP
Parts Problem
Parts Problem
Q
Ok,take two F-body cars...both with caltracks.
One car has a front seg. length of approx 17 1/2 inches.
The other cars front seg. is 4 inches longer at approx 21.5 inches.
Would it stand to reason the longer front segment setup would work better then the shorter of the two...
THANKS!!!
Re: Another Cal Track Question???? [Re: quick77rt ] #820137
10/02/10 08:24 PM
10/02/10 08:24 PM
Renton Washington
Triple Threat Offline
Renton Washington
Not really, you don't want the front portion to flex, thus why people clamp springs, and the fundamental point behind the bars themselves. You want the power to transfer forward through the chassis, not upwards.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Another Cal Track Question???? [Re: Triple Threat] #820138
10/02/10 08:28 PM
10/02/10 08:28 PM
Q
Parts Problem
Parts Problem
Q
Hmm....no clamps...Mono-Springs.
I thought I might be onto somthing.
Re: Another Cal Track Question???? [Re: quick77rt ] #820139
10/02/10 08:57 PM
10/02/10 08:57 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
IMHO, the closer the front spring eye bolt is to the 100% anti-squat line, the better......... but, I know some NHRA Stocker racers have moved their front spring eyes forward to calm their cars down.......(but, that may have just moved it closer to 100% anti-squate )
If you can't handle the truth, you're living a lie.......
Re: Another Cal Track Question???? [Re: Big Squeeze] #820140
10/02/10 09:01 PM
10/02/10 09:01 PM
Q
Parts Problem
Parts Problem
Q
Currently the short setup does not squat one bit on launch, it used to lift the rear a hair until I slowed down the ext rate on the shocks.
Re: Another Cal Track Question???? [Re: quick77rt ] #820141
10/02/10 10:03 PM
10/02/10 10:03 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
Cool..........IMHO, you don't want squat or rise....The way I've always done it is if the track is really good, the rear shocks have to be very stiff to keep it to where it just rises a 1/2"......when the track gets worse, the shocks need to be looser and looser to get it to rise that 1/2".......
What problem are you having?
Re: Another Cal Track Question???? [Re: quick77rt ] #820142
10/03/10 10:46 AM
10/03/10 10:46 AM
New York
Dustin71 Offline
Dustin71  Offline
New York
i have stock multi leaf with the cal tracs
and it rise's alot !!!!
Re: Another Cal Track Question???? [Re: quick77rt ] #820143
10/03/10 11:55 AM
10/03/10 11:55 AM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
i'm with you on that, the angle on the adjustable bar changes quite a few degrees as soon as the as the car lifts or the tire separates. if four link cars changed several degrees of angle on the launch, there would be issues there. if the bar on the cow tracks (like that on the chevy and ford) was longer it would have less of a angle change. after doing every thing that calvert suggested i pulled of all his stuff off and went to ladder bars with coil overs. i'm happy now
Re: Another Cal Track Question???? [Re: quick77rt ] #820144
10/03/10 05:59 PM
10/03/10 05:59 PM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
Other makes springs are more centered than mopars, and they react differently.
The little I talked to Calvert a while back, Mopars separate more cuz of the shorter front segment.
Personally feel there is perfomance advantage with longer front segment but have no data or supporting facts.
Mono's work excellent.
Re: Another Cal Track Question???? [Re: theclutcher] #820145
10/03/10 10:22 PM
10/03/10 10:22 PM
Staten Island N.Y.
Dap Offline
Dap  Offline
Staten Island N.Y.
Here is a thread from YB with a TON of great info about Caltracs
http://www.yellowbullet.com/forum/showthread.php?t=271194
PRH446
10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
Re: Another Cal Track Question???? [Re: Dap] #820146
10/03/10 11:48 PM
10/03/10 11:48 PM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
Now that is a thread.
Thanks much,
Re: Another Cal Track Question???? [Re: theclutcher] #820147
10/04/10 12:03 AM
10/04/10 12:03 AM
Q
Parts Problem
Parts Problem
Q
Yes, Thanks... thats alot of good info.
I guess either way im ok on the bars, it seems I just need to go alot lighter front spring in the alterktion, two oil pans pushed into the pickup, pushing the pickup tube into the crank, ect in one year has me a bit "skidddish" ha ha! on going to a lighter spring for better travel even with QA1 Doubles at all four corners.
Re: Another Cal Track Question???? [Re: theclutcher] #820148
10/04/10 12:22 AM
10/04/10 12:22 AM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
Thanks much,
I also thank you guys for the pointer to that great thread. Now I'll need to do some fabrication work and see if I can put what I learned to some good use!
Re: Another Cal Track Question???? [Re: Duner] #820149
10/04/10 01:07 AM
10/04/10 01:07 AM
Staten Island N.Y.
Dap Offline
Dap  Offline
Staten Island N.Y.
Ohh yeah on page 5 it is mentioned that poster Jeff C is running an 8 3/4 with a stock 489 case with billet caps and 60' in the low 1.20`s..
PRH446
Re: Another Cal Track Question???? [Re: Dap] #820150
10/04/10 01:19 AM
10/04/10 01:19 AM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
Looking at your signature.....
Man do I need some help myself! hahaha
Exact same mph.....
10.61 @ 133.65 with a 1.735 60'
I think I might be leaving just a little bit on the table.
Re: Another Cal Track Question???? [Re: Duner] #820151
10/04/10 06:13 AM
10/04/10 06:13 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Duner! My first outing at the track I would run a 10.6 with a 1.7 60ft with caltracs and radial.. got it to hook some to a 1.46 and went 10.08 all in crap air! The more I hooked with the radials the mph went up also. Shame I never got to try my afco double adjustables
Mopar Performance
Re: Another Cal Track Question???? [Re: moparniac] #820152
10/06/10 01:15 AM
10/06/10 01:15 AM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
Wow! I sure hope I can get some results like that. I tried radials and it won't even try and hook with them right now. I'm really looking forward to some fab work and some results.
Re: Another Cal Track Question???? [Re: Dustin71] #820153
10/06/10 01:21 AM
10/06/10 01:21 AM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
Obbie,
I know you dont want to here this
Mono leaf, and a set of Rancheros
